charcoal canister help
Old May 26, 2026 | 05:39 PM
drbutton's Avatar
drbutton
Default charcoal canister help
One of the valves in my charcoal canister (1988 Corvette) has failed some way, and gas fumes are streaming out of the tank around the gas cap once the car is running warm. I cannot buy the whole unit again - at least not a form that looks like what was stock. What is the best solution?
Old May 27, 2026 | 08:57 AM
82-T/A's Avatar
82-T/A
First thing I would do is verify that the line is in fact not crimped or anything. Disconnect at the fuel sender (by the gas cap), and then disconnect by the charcoal canister, and see if you can blow through it (and have someone on the other side feel for air). If you cannot, that's your problem.
Otherwise, I would also check the vacuum to the cansiter as well to make sure it's actually good.
Old May 27, 2026 | 04:29 PM
Natty C's Avatar
Natty C
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
Have you inspected the tank itself? There's a couple of places that you really just can't see, even with a flashlight. Particularly the area adjacent to the rear bumper cover.
My tank was rotted and split all the way across, which I only discovered after buying the car when it failed a tank pressure test in the inspection lane. Apparently, the only thing holding fuel in the tank was the bladder. Which itself eventually started to leak. The fumes were really bad and naturally rose upward, giving the illusion that it was coming from the cap.
But, maybe it'll be something simple like a valve.
Old May 27, 2026 | 05:25 PM
drbutton's Avatar
drbutton
Thank you for the diagnostic suggestions. I will revisit all of these ideas with my mechanics. All the same, my mechanics and the body shop that removed all of the rear components to repaint the rear bumper/spoiler this week. They inspected the lines, vacuum hose and canister components and function. They looked for other issues and found nothing amiss with the fuel tank. Its that canister unit that requires replacement - so I need the part. Any sources for this part or a substitute that works?
Old May 28, 2026 | 01:50 AM
Natty C's Avatar
Natty C
Yeah, they would have seen the place where it rots and splits if tey removed the bumper cover.
So far as the canisters, I don't think you can get em aftermarket.
It'd have to be a used one, so far as I know.
And I imagine any used one is more likely to be someone elses old bad one.
Just to add to what 82-T/A had mentioned, though, maybe also blow out all of the vacuum lines attached to the canister. I've read of those getting clogged up with charcoal granuals.
I've also read where people have cut the bottom of the canister off and replaced the charcoal filter and then did a sort of plastic weld to reattach the two pieces afterward.
Anyway. Good luck with it...
Old May 28, 2026 | 07:50 AM
82-T/A's Avatar
82-T/A
Yeah... for some reason, I've never seen charcoal canisters being offered anywhere in the aftermarket for early to late 1980s. You can find them for early 1990s and up all day long though.
They do sell the purge valves: 91 1991 Chevrolet Corvette Vapor Canister Vent Valve - Air Intake - Dorman - PartsGeek (universal) ... but you'll have to learn to do plastic welding. :/
Best bet is to find a good original one. I would call Corvette Generations.
Old May 28, 2026 | 09:29 PM
DanZ51's Avatar
DanZ51
I would suggest doing a thorough inspection of your Evap system. I checked all my lines going back to the tank - no blockage, replaced my rubber hoses, determined the separate vacuum valve was stuck -replaced it, then rebuilt the charcoal canister for good measure -there's Youtube videos on that, cut it open/glue it back together.
Old May 30, 2026 | 08:57 AM
Natty C's Avatar
Natty C
Heck, I had trouble finding one out of a '90, so ended up just leaving well enough alone.
A lot of times I'll buy a part if I stumble across it on the www, regardless of whether I actually need it or not, if it's a part that I know is or is nearing unobtanium.
Like that NOS incandescent power driver, for instance. I knew I'd need that thing some day, so bought it when I saw it listed, and two years later, sure enough, I needed it and all I had to do was go pull it off the shelf and install it when I noticed that the button lights had went out.
Old May 30, 2026 | 11:03 AM
82-T/A's Avatar
82-T/A
Oh man... you should see my attic. A bunch of stuff I'll never use, but I'm convinced I will.
The reality is... someone COULD use that stuff.
I have a rental in South Florida that I haven't lived in, in over a decade. The attic is filled with ultra-rare 3rd gen parts, which I never viewed as rare, including a factory fiberglass cowl hood, and like three sets of cowl induction systems for 82-84 F-bodies. A couple of shaker assemblies, some unobtanium Holley TBI units... none of which I'll ever use, but at the time I thought I would. It sounds hoardery, but it really isn't as bad as I'm making it seem. But all that's been sitting in the attic of a rental. If I eventually move back, I'll probably just give all that stuff away.
Old May 30, 2026 | 05:50 PM
Natty C's Avatar
Natty C
Could always run a sale for pickup only if you don't feel like shipping stuff. It'll git got rid of in due time. At least you know where everything is. Ha...
Old Jun 1, 2026 | 03:41 PM
drbutton's Avatar
drbutton
Great suggestions all - thank you! I'll get back with everyone on what happens next, and I'm checking on that valve [[url]https://www.partsgeek.com/catalog/1991/chevrolet/corvette/air_intake/vapor_canister_vent_valve.html] to see if it's the fix. I hope so.
One other note...I did change the gas cap at the suggestion of the mechanic. With the car cold (not run for days) at about 70 degrees, the vapor pressure in the tank was high as fumes rushed out with the cap removal. Its not a cap issue.
Old Today | 01:53 AM
adamw412's Avatar
adamw412
I recently ran into a fuel pressure issue myself. I posted this thread here a couple months back. I got some good suggestions, and schematics too from others here. I cut the charcoal canister open, refilled it and put it back together, a purge valve, and a couple other things. It worked for me. I don't have any issues now.
To charcoal canister help
