Fiberglass damage under driver floor pan
Old Jul 10, 2022 | 10:48 AM
MarkGM's Avatar
MarkGM
Default Fiberglass damage under driver floor pan
Just bought a 95 and want to repair this damage that i knew was there when i bought the car. I am not sure if it goes all the way through the floor pan.
Any tips or suggestions before I pick up a fibergla
ss kit and start sanding? I will pull the carpet back first to get a better look.
Old Jul 10, 2022 | 11:15 AM
FostersPerformance's Avatar
FostersPerformance
Yup. Pull carpet back and look at damage...grind and cut all the damage out. Sand the surrounding area with anything heavier then 200 grit (use 80 if you have it...Acetone the area and start the repair..you can use any resin, but I'd recommend west system epoxy resin. You can use blue tape on underside to get the shape correct as you lay up the glass from the inside. Dont expect to get it in one shot, will take a few layups to do it right. Pull blue tape off, then you can undercoat the bottom, or paint it..on the inside you can smear some seam sealer over the repair, but not necessary. Make sure you have no voids in the glass.
Old Jul 10, 2022 | 12:12 PM
MarkGM's Avatar
MarkGM
Much appreciated. I can handle that.
Old Jul 10, 2022 | 03:36 PM
Natty C's Avatar
Natty C
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
When I bought my '90, it had that problem. Which I did not know, as I bought it from a web listing and it wasn't mentioned.
I ended up going down to the marina and paying a boat repair guy to fix it.
The damage on mine was on the front of the pan. So there's metal up there in that area. That's why I didn't mess with it myself. Don't see any metal in your photograph, though, so probably none back there.
Old Jul 12, 2022 | 06:51 PM
Yonker's Avatar
Yonker
That is the dreaded push the jack to far under car damage..I fixed mine last year but mine was more superficial. Good luck.
Old May 22, 2026 | 03:39 PM
97SLVRC5's Avatar
97SLVRC5
Oof - I just notice similar damage but to a much lesser extent.
How did your repair go? Sorry to dig up an old thread.
Old Yesterday | 10:42 AM
Railroadman's Avatar
Railroadman
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
On my "To Do" list as well. Brian's post will be a help, going to print it off now.
Old Yesterday | 07:20 PM
MarkGM's Avatar
MarkGM
Still have the repair kit sitting on my workbench. Too many projects on my 65 Corvair and projects to prep the Vette for track weekends.
Old Today | 01:02 AM
BluColr's Avatar
BluColr
3rd Gear
I've got some soft spots I noticed while changing out my wheels. Not this bad. but its does seem I'll need to do some sifting repairs here in the near future.
Old Today | 12:26 PM
97SLVRC5's Avatar
97SLVRC5
I'm not sure if I feel better knowing that this is a common issue, lol - but it is added to my list of notes that make a C4 a less than ideal as a daily driver, and perhaps better for occasional use.
That said, it is also why I have two - one with lower miles that I try to keep pristine for weekend drives, and another that I bought to put miles on, drive the dog around in and not care about the wear these tasks present.
Old Today | 12:43 PM
82-T/A's Avatar
82-T/A
Hey, please take a look at this video my daughter made when she restored the decklid of her Pontiac Fiero. It's not a Corvette (though she does have an 84 and will be doing fiberglass repair), but remember that the C4 is not actually fiberglass, but SMC (exactly like the Fiero). There are multiple areas of the Corvette that are a combination of different SMC parts, which share the identical compound as the Fiero's decklid, hood, and roof. Do not use normal fiberglass repair compound, use the specific SMC and hardner compound. See here:
Old Today | 02:37 PM
BET VETTE's Avatar
BET VETTE
This should work
Old Today | 02:48 PM
97SLVRC5's Avatar
97SLVRC5
Nice recommendation - any clue what the consistency is? My damage doesn't break through and I'm hoping to repair from the underside, which, would require something thick enough to avoid dripping.
Originally Posted by BET VETTE
This should work
Old Today | 03:09 PM
BET VETTE's Avatar
BET VETTE
Old Today | 03:19 PM
97SLVRC5's Avatar
97SLVRC5
Thanks for this - would like your opinion -
Although, I'm not sure what I am looking at on the first picture, but, it looks like I might get away with the repair based on picture of the epoxies. I'm thinking - prep area and apply with popsicle sticks or a small putty knife. And then be done with it since there's no need for it to be perfect.
Other's have mentioned repairing from the inside, but I'm thinking that would be overkill for my situation.
Chipped floor pan on 1996 C4
Old Today | 03:56 PM
BET VETTE's Avatar
BET VETTE
It’s similar to an epoxy job, mix..apply.. but try to get the best shape before it hardens unless you want to do some sanding . Like you said it’s under the vehicle so it shouldn’t matter
Old Today | 04:13 PM
97SLVRC5's Avatar
97SLVRC5
Thanks, I appreciate it. This is new territory to me - I've used spackle on drywall and hydraulic cement patch, but, that's about it lol.
I'm going to give this an attempt because there isn't much to lose by trying.
To Fiberglass damage under driver floor pan
82-T/A's Avatar
82-T/A
I would rough it up with a wire brush (not a circular drill attachment, but a hand-held wire brush). What you want is to make sure it has something to actually bite into. I would also sand around the edges of where the damage ends. Normally, you would want to drill a little hole in there too in order to give it more to bite on, but not really necessary in this case.
Use a putty knife to smooth it over, and then when dry, sand it down to a smooth finish and paint it.
Old Today | 04:17 PM
97SLVRC5's Avatar
97SLVRC5
Thanks for the tips.
Is the paint seal the work or just clean it up visually?
Old Today | 06:32 PM
82-T/A's Avatar
82-T/A
Both. Ideally... the SMC has a gelcoat property to it... but the paint helps seal it. If you look at older C4s that have sat out in the sun, once the paint flakes away, the SMC starts to really decompose in the elements fairly quickly.
