C3 Parts for Sale/Wanted C3 Corvette Performance Parts, Rare NOS and NLA Chevy Parts, Wheels & Tires, Exterior Enhancements, Aftermarket
FS: Rally Red 974 Lacquer
Old May 29, 2021 | 06:03 AM
Argentimage's Avatar
Argentimage
Default Rally Red 974 Lacquer
About two years ago - the components to make the real (leaded) DuPont-PPG formula Rally Red became nearly impossible to find.
Even before that, Hibernia was at $2500 a gallon at the point they discontinued it June 2018.
I have several fresh gallons available, the master DuPont PPG paint chip dated from 1965, all the real deal PPG.
Message me ONLY if you understand real cost in 2018 and its now 2021.
and are ready to purchase - now PPG Quarts $1200.00
Old Mar 22, 2022 | 03:28 PM
Argentimage
New Price $950 per quart plus FEDEX or UPS
Old Jun 22, 2022 | 02:11 AM
Argentimage
the real deal
Old Apr 19, 2023 | 06:49 AM
Argentimage
When PPG/Duont discontinued the Orange that contained some lead that makes it look and flow like rally red lacquer should,
I contacted every dealer in the paint network across the entire USA to obtain any and all rally red components.
Quart price above. They tell me cars take 2-2.5 gallons, message me and we go from there.
A quart will do survivor touch up for the stone chips and nicks...and according to the shops I know that have done this to 66 BB cars out east, its very hard to detect.
Old Apr 30, 2023 | 08:20 AM
Argentimage
ttt
Old Aug 4, 2024 | 09:15 PM
Argentimage
Ttt
Old Sep 19, 2025 | 05:07 AM
Argentimage
bump
Old Dec 11, 2025 | 05:09 AM
Argentimage
bump
Old Dec 11, 2025 | 07:24 PM
Rowdy Rat's Avatar
Rowdy Rat
Veteran: Marine Corps
How much do you have?
Problem is that none of the red oxide lacquer primer is available either, nor is the gray primer sealer.
Regards,
Stan Falenski
Old Dec 11, 2025 | 08:24 PM
Argentimage
The red oxide is not primer
its a primitive epoxy sealer
The blue gray primer … critical to achieve proper red color due to reds naturally being translucent can be easily made, you have to know
red oxide primer was still available as was a gray base that you then make blue gray
Old Dec 11, 2025 | 08:50 PM
Rowdy Rat's Avatar
Rowdy Rat
The red oxide was most definitely a primer. There is nothing “epoxy” about it. It WAS baked on, which is probably the reason it is so difficult to remove. The gray sealer was sanded after application… Often to the extent that it was almost removed completely. I’ve spoken to guys who worked painting these cars. The products just mentioned were lacquer based (back when the lacquer was good).
Didn’t mean to get into a tangent on primers. Good luck with your sale.
Regards,
Stan Falenski
Old Dec 11, 2025 | 11:19 PM
Argentimage
Stan
the red oxide sealer was Not lacquer
Someone here can post its technical name, Ncrs etc has it John Hinckley Darrick’s on the process
Completely incorrect
I have red oxide primer and it’s wrong material to put on raw mid 60s fiberglass, it does not seal the surface and remains thermoplastic, not cured
I was about to go into the chemistry of lacquer, but let’s leave it that heat doesn’t make it hard to remove
lacquers flow in heat
at GM we had flowcoat ovens, smooth as glass after bake
They are thermoplastic and remain thermoplastic
regardless the materials to identically replicate original are available
Old Dec 12, 2025 | 12:50 AM
Rowdy Rat's Avatar
Rowdy Rat
Straight from the GM Engineering Center… Both red and gray coats were considered primer (#2). While listed for 1963 to 1967 Corvettes, it would have held true for all St. Louis built C3s as well that used lacquer paint. There is no mention of the chemical composition, but I’d be willing to bet that the process was more evaporative (like lacquer) than catalytic (like epoxy). However, without having any documentation as to the exact make up, I can’t provide proof on this aspect and am open to options.
Regards,
Stan Falenski
Old Feb 3, 2026 | 04:26 AM
Argentimage
ttt
Old Mar 16, 2026 | 04:18 AM
Argentimage
ttt
Old May 11, 2026 | 04:38 AM
Argentimage
bump
To Rally Red 974 Lacquer
