C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Ac compressor doesn’t come on
Old May 9, 2026 | 09:06 AM
yzrider's Avatar
yzrider
Default Ac compressor doesn’t come on
Where to start?
turn defrost or set temp to low and compressor never engages?
any recommendations on steps to take.
thanks!
heat works and controls on hvac all work.
Old May 10, 2026 | 11:20 AM
Drbobzr1's Avatar
Drbobzr1
2021 C4 of the Year - Modified Finalist
if you just replaced the orings, or recharged the system , disconnect the battery and reconnect it 5-10 minutes later...the ecm has to re-set......(sometimes helps to pray to the zr1 god).....Happened to me when I replaced the orings/recharged. Started up and A/c worked as it should...
Old May 10, 2026 | 11:53 AM
yzrider's Avatar
yzrider
I haven’t done a thing yet. I’ll start with checking the charge then I guess: that’s a symptom of being low/empty?
Old May 10, 2026 | 12:49 PM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Is the 1st ac light on the HVAC dash head unit flashing? if it is your low on Freon. You can get diagnostic help thru it.
Old May 10, 2026 | 01:33 PM
Drbobzr1's Avatar
Drbobzr1
Steve....your video is so good...easy to understand and 1000's of time better then wild guessing.....appreciate it much...thanks bob
Old May 10, 2026 | 03:49 PM
FASTAZU's Avatar
FASTAZU
St. Jude Donor '16
Thanks Rd Bob hope it helps someone!
Old Yesterday | 07:12 PM
mrlmd's Avatar
mrlmd
One more thing - If you have the 09 code because of low Freon, the compressor will not run, and you must have the compressor running to add Freon to the system. You must reset the computer by disconnecting the battery for 30 sec. or so, then reconnect it, then bypass the low pressure switch so the compressor runs, then add Freon. After you get enough in, you can reconnect the low pressure switch plug and add the rest up to the required amount needed.
To Ac compressor doesn’t come on
