Looking for ECM Information
Old Yesterday | 03:40 PM
CorvetteRules's Avatar
CorvetteRules
Default Looking for ECM Information
Some may remember the post I made about my 95 that had cut out will I was driving. I had it towed to garage I use since they would have diagnostic tools I don't have. It was originally thought that the fuel pump was the problem because at that time was showing no fuel pressure but while playing with it was found that the pump did rum of the few second prime but still would only crank. The attention then went to the ECM because the old OBD1 they hooked up indicated the ECM is not sending the required signals..
Keeping in mind no codes are showing can someone provide me with the best way to confirm the issue is indeed with the ECM? If additional diagnostics proves it is the ECM what venders are recommended to rebuild it at a reasonable cost and time frame??
Old Yesterday | 03:54 PM
82-T/A's Avatar
82-T/A
I don't have a 1995, but from what I understand, there's a DIC which provides codes on the center dash screen, is that correct?
The ECM itself, if you can ground out the diagnostic wire, will flash the "SERVICE ENGINE SOON" light, and this is the old school way of getting ECM codes, to see if your ECM is actually good. You should get a CODE 12, which will look like this, "FLASH - PAUSE - FLASH FLASH" and then it will do it two more times. After that, you should see some other flashes if there are actual trouble codes... and it'll flash each trouble code three times, and then finally, it'll go back to flashing code 12. If you just get a steady flash that doesn't end... or no flash at all, that usually means there's something actually wrong with the ECM itself.
Here is a video that explains how to check the codes "the old way" in a newer C4 Corvette (not my video):
If you get a code 12 (as indicated), then your ECM is actually OK, and then it's probably something else.
Old Yesterday | 04:16 PM
CorvetteRules
They had an older OBD1 tester at the garage which showed no codes while showing information that indicated the ECM wasn't sending certain signals. It is very easy to show codes on a 95 by shorting the 4 and 12 pin of the OBD connector. Some members here are very knowledgeable in diagnostics of the ECM so hoping they can direct me in that regard.
Old Yesterday | 05:13 PM
82-T/A's Avatar
82-T/A
Ok, and yes... did you do that?
Old Yesterday | 05:31 PM
CorvetteRules
In regards to the garage I said "They had an older OBD1 tester at the garage which showed no codes".
Old Yesterday | 06:09 PM
82-T/A's Avatar
82-T/A
Dude... is this work beneath you? Stick the pin in and try it yourself. I don't trust mechanics, certainly not the younger ones who have no idea what OBD1 even is.
You asked this: "can someone provide me with the best way to confirm the issue is indeed with the ECM?"
This is it. If you're not getting a flashing service engine soon, then yes, your ECM is dead, or the pins on the ECM harness connector are unsoldering from the board and you need to send it in for repair or repair it yourself with a soldering iron.
I'm trying not to be mean here... but I get so frustrated on Corvette Forum sometimes because like HALF the posts are people who refuse to do even the most basic work on their car, but waste everyone's time and then take it to a shop anyway, get screwed, and the car ends up on eBay or Bring a Trailer.
Old Yesterday | 07:10 PM
CorvetteRules
Why are you so butt hurt? The SES light did not come on so I'm not surprised about no code. In the car just died while I was going down the road. It just cranked with no indication of ignition. I had AAA take it to garage I've used for my vehicle for over 30 years with 2 older mechanics that originally worked in Chevy dealers. They would have more experience then I could ever have with a thirty year old car. I have completed a number of repairs on my 95 since owning like different sensors and fuel pump. Your reaction troubles me. I know very little on diagnostic steps on the ECM which is why I came here to get help. With the information I get here I can intelligently talk with the mechanics at the garage. If you think what I'm asking is a waste of your time you have the right for that opinion but I'm hoping I can get some ECM diagnostic information that will help me ensure I'm going in the right direction. While I've known the mechanics for many, many years I still want to be able to ask them questions
One more bit of information I can add to all of this is I do remember the tachometer never moved while the engine was cranking. I do remember reading threads in this Forum that it be important diagnosis information for some issues.
Old Yesterday | 07:38 PM
82-T/A's Avatar
82-T/A
I'm asking you to do very basic things as part of the diagnostic process and you seem incapable of doing them, yet want someone to just give you an ephemeral answer.
1 - Did you, or did you not put a paper clip in the ALDL connector and see if it gives you code 12?
2 - If you saw nothing, you can also try checking to make sure that you don't have a blown ECM fuse (I think it's slot 33 in the fuse panel)
3 - If the fuse is fine, and you don't get a flashing SES code, then it's possibly a bad connection at the ECM (try jiggling it), or the ECM itself is bad.
For these older ECMs for your year of Corvette, it is a known issue for the pins to desolder from the board, and break connection. There is a shop that a lot of people here use to have their ECM's repaired.
Old Yesterday | 08:52 PM
CorvetteRules
The vehicle is not at my house and my schedule has not allowed me to go to location it is at, but I have no issue with confirming some basics when I can see it in person. I actually have a male OBDll connector that I shorted out the 4 and 12 pins so I don't have to crawl under the dash to use a paperclip since the OBD scanner I have that reads l and ll gets an error message reading my 95.
The information you just provided is the type of information I was hoping for to feel good before I send the ECM out for repair. Some of the ECM repair sites I have checked into have wide variations in cost and timetable for return. I will check the items you mentioned when I can go to where the car is. Your help is greatly appreciated. To me this is why this Forum is such an important place for owners seeking an education.
Old Yesterday | 08:54 PM
82-T/A's Avatar
82-T/A
Sorry... I thought you had the car back home in your garage.
@IHBD knows the name of the specific shop. If the connectors are screwed up, he can recommend the right place to send your ECM.
Old Yesterday | 09:06 PM
WVZR-1's Avatar
WVZR-1
I believe it would be good to first understand that your '95 does NOT have a traditional ECM. '95 was the second year for the PCM in the corvette. There should be many, some maybe even somewhat local that understand 'The PCM'. You need to understand the diagnostics involved and start from scratch. NJ location there actually might be tuners that could evaluate your car while running and do some diagnostics for you. I don't believe you just ship and pray that it will return fixed.
Start diagnostics from scratch!
Old Yesterday | 11:15 PM
CorvetteRules
I definitely don't want to mail it off to a vendor that advertises they can repair the ECM/PCM if there is a better way to resolve my issue. As I previously posted I will do some hands on diagnostics and add to my post with what I find with my limited knowledge and post my findings.
Old Today | 12:19 PM
CorvetteRules
I was able to look at my 95 for a few minutes today and shorted 4 and 12 pin and came up with H codes 31,33,35,37,72 and 74. It appears the 30 codes all concern the CCM and I don't know if any of those have any relationship to an ECM/PCM issue. I didn't clear the codes since the car is not running so I couldn't see if codes reappeared. Unfortunately I forgot to check the ECM fuse so will have to look next time I can get over there.
With the key to the run position the SES light stayed on steady with no blinking. I can hear the fuel pump run to prime but no fuel pressure and car just cranks. Does the information above give anyone additional diagnostic steps I should attempt??
Old Today | 12:41 PM
range96's Avatar
range96
Check the MAF and grounds
To Looking for ECM Information
