Bettter C5 Shifters...Which One?
Old May 10, 2026 | 01:07 PM
chefgordiemac's Avatar
chefgordiemac
Default Bettter C5 Shifters...Which One?
Ok, do I pick the MGW, Tick, Fidanza, Hinson or the C6? Or???
Opinions and why...
Thanks
Old May 10, 2026 | 07:04 PM
Lowend's Avatar
Lowend
Here’s the thing about C5 shifters, most of them do the same thing. You can move a pivot point to change the ratio and remove slop… that’s kinda it.
I like the Tick and TMod as they both replace the boxes and eliminate a ton of slop.
https://tmodcustoms.com/collections/...so-shifter-kit
Old May 10, 2026 | 09:27 PM
AtkRWC's Avatar
AtkRWC
I've had my TMOD for several years. No complaints and would buy it again.
Old May 10, 2026 | 10:33 PM
Midwest19942000's Avatar
Midwest19942000
Another fan of the TMOD. Shores up all the slop and I’m certain of which gear I’m selecting. It’s one of those “should have come from the factory like this” type of improvements. I went with this option because I was not looking for a notchy short throw shifter experience. Nothing wrong with those but I found the TMOD to be the perfect solution for just everyday street driving.
Old May 11, 2026 | 05:12 AM
Tusc's Avatar
Tusc
Running Guns & Moonshine
I love Tmod for his tubs. I tried a free spinning shifter and it was not for me or my cro magnkn wrist. You have 3 good dudes here, but those shifters almost ne er get that heavy a response.
By all means, his tubs are amazing and I fully recommend the linkage mod next time you change the clutch.
I dig the older use MGWs personally. Light. Goes into a tmod tub. Awesome.
Tick is a monster too. You'll never miss a gear. It has less slop in the shaft travel and so it is great for guys driving hard because you don't ever need to think.
Best perfect function and fitment without the racer feel? Callaway. They got that one nailed.
Old May 11, 2026 | 08:31 AM
PaulWall's Avatar
PaulWall
I prefer the c6Z shifter. Ive had it for probably 15 years and wouldnt change it
Old May 11, 2026 | 08:48 AM
G Man's Avatar
G Man
I was sold on the TMOD until I learned the shift arm is free spinning. For that reason, I went with the MGW. If the shift arm was fixed in place, I would have definitely bought the TMOD.
Old May 11, 2026 | 09:02 AM
Alkay3's Avatar
Alkay3
I have the MGW and really like it. Good quality and really tightens up the shift.
Old May 11, 2026 | 12:29 PM
helga203's Avatar
helga203
what is the shift Amr??? I have TMOD and its great.
Old May 11, 2026 | 12:44 PM
arthursc2's Avatar
arthursc2
The shaft the **** threads on to. The TMOD allows this shaft to rotate freely within in the pillowball
Old May 11, 2026 | 01:20 PM
MetalMan2's Avatar
MetalMan2
My journey was as follows: stock --> C6 upper shifter --> C6 upper with TMOD lower --> full MGW (#1) --> C7 upper with TMOD lower --> Hurst C6 with TMOD lower --> full MGW (#2) --> Hurst C6 with TMOD lower. Also tried a custom-shortened C6 shifter but that didn't really work out well. And note that the C7 is the same as C6 but with a better dust boot.
First MGW occurrence, I found the side-to-side effort was excessive especially for my daily-driving-in-traffic use case. Back then I was 30 years old and quite strong from regular gym attendance.
2nd MGW occurrence was 2.5 years ago while I serviced my Hurst C6 shifter (I got a good deal on this MGW and wanted to give MGW a try again). Same deal as first time, just didn't like it and was very happy to return to Hurst C6 with TMOD lower box. Yes I've played around with anti-venom mod.
With Hurst C6 + TMOD lower box there's pretty much no slop in my shifter while in gear. Should mention my shift linkage was upgraded by TMOD and I rebuilt the trans 6 years ago. Shifting just feels so good, and going through the gears the throw is plenty short and the overall experience is very rewarding.
Old May 11, 2026 | 06:26 PM
helga203's Avatar
helga203
Old May 11, 2026 | 08:37 PM
Kalashz06's Avatar
Kalashz06
3rd Gear
I was thinking damn I am weak attempting to locate reverse on my new to me car, it has the mgw installed. Going to try the anti venom first
Old May 12, 2026 | 12:48 AM
Lowend's Avatar
Lowend
Psst
https://tmodcustoms.com/products/rev...t-modification
Old May 12, 2026 | 08:20 AM
lucky131969's Avatar
lucky131969
My short journey started with the stock shifter. Not appalling, just average. I then tried a Hurst shifter. I have had or installed hurst shifter/linkages in every manual transmission car I have owned, so it seemed like a safe bet. Well, the Hurst was the worst. There was no amount of adjustment that was ever going to make the shifter run well. Notchy, stiff, unpredictable shifting. I then went to a C6 ZO6 shifter modified by RSD, and have not looked back. Smooth, predicable shifting.
https://www.racespecialtydesigns.com...?productid=113
Old May 12, 2026 | 09:29 AM
Tusc's Avatar
Tusc
I did enjoy the bent handle C6 Z06 shifter. Certainly the best I've had from GM.
Old May 12, 2026 | 11:08 AM
-ZEEOHSIX-'s Avatar
-ZEEOHSIX-
One thing I've learned about shifters over the years, is that they are one of the most subjective components on a vehicle--similar to asking which exhaust sounds the best. I, for one, appreciate the effort and notchiness of the MGW. If my car didn't already have one, I would have gotten one anyhow. But, that doesn't mean that I don't appreciate the smooth, near effortless feeling of the stock or stock-like shifters. There's a lot to be said about a buttery shift but, given a choice, I prefer a very mechanical feeling shifter and that works for me but, clearly not everyone else.
In my Mustang's, I've been exposed to the Pro 5.0, Steeda Tri-Ax, Barton, MGW, etc. I'd say that the Barton and MGW were the closest to feel and quality with the Tr-Ax being a nice compromise between stock and an upgraded model. The Pro 5.0 felt like it was OEM+ and that appealed to a lot of folks. For me, the 2-3 shift spring/guide is money and where I will spend good money to help make that shift more reliable.
To Bettter C5 Shifters...Which One?
Old May 12, 2026 | 07:35 PM
MetalMan2's Avatar
MetalMan2
Anti-venom only affects fore/aft effort. Side-to-side effort is 100% controlled by the centering spring in the transmission and the shifter you're using. So you might still like it better with anti-venom mod (ball detent washer) but don't expect it to improve your ability to reach reverse gate.
Core shifters also makes a lighter weight spring. I have one and tried it during my first MGW experience. For me it didn't help appreciably with the side-to-side effort when entering reverse, so I swapped back in the stock spring after putting the C6 shifter back in. And now with the Hurst I don't have a challenge with side-to-side effort including with the stock reverse lockout solenoid spring.
Old May 12, 2026 | 09:34 PM
Tusc's Avatar
Tusc
Has anyone tried the lighter reverseockout spring mod yet?
Old May 12, 2026 | 10:56 PM
Bluefire's Avatar
Bluefire
I concur. When I was tracking my C5 I put a C6 Z06 shifter in. I could confidently palm shift it.
