Engine Mods Outrageous Builds, High-Horsepower Modifications, strokers, and big cams for the Corvette
How much power is needed to cut tires loose at 50+Mph?
Old Nov 3, 2003 | 01:27 PM
scorp508's Avatar
scorp508
Default Re: How much power is needed to cut tires loose at 50+Mph? (Z-man)
Scorp - Haven't you noticed? The guy who gets even the smallest puff of smoke from his tires loses the race...!!!
Theres a difference between a few rotations and hazing your tires though. :) If those suckers dead hooked they'd explode. Its a delicate science I'll never fully understand between allowable tire spin and clutch engagement.
Old Nov 10, 2003 | 11:53 PM
J Z06's Avatar
J Z06
Default How much power is needed to cut tires loose at 50+Mph?
My little 383 lights them up hitting the gas WOT at 45-50 mph. Revs go right to the limiter.
It's a terrific feeling!!! :smash:
Old Nov 11, 2003 | 01:01 PM
red L98's Avatar
red L98
Default Re: How much power is needed to cut tires loose at 50+Mph? (Jay 383)
my young brothers 2000 camaro SS goes sideways going 70 mph on the
freeway he got the 427 Ls6 motor 4000 stall yank and 323 rearend the car is
3200 pounds fast just go it tuned last weekend it made 500 HP and 480 TQ
with that big converter and 12 bolt rear end tha car is fast almost as fast as
my vette :steering:
Old Nov 14, 2003 | 08:02 AM
norvalwilhelm's Avatar
norvalwilhelm
Default Re: How much power is needed to cut tires loose at 50+Mph? (MrNuke)
And what mods / HP are you running?
MrNuke I am running a 8-71 blown bigblock :)
Old Nov 14, 2003 | 11:09 AM
MrNuke's Avatar
MrNuke
Default Re: How much power is needed to cut tires loose at 50+Mph? (norvalwilhelm)
Stock 350 Shortblock/cam, aftermarket heads, every bolt-on and trick in the book, LPE Superram/headers, 3" Exhaust, CAT.
Old Nov 14, 2003 | 07:11 PM
Bearcat's Avatar
Bearcat
Chuck, your L88 clone appears to be a lot like mine. I'd like to feel mine at sea level. Wow.
Old Nov 15, 2003 | 06:57 PM
norvalwilhelm
Default Re: How much power is needed to cut tires loose at 50+Mph? (red L98)
redL98 where did he come up with a 427LS6 motor?
Old Nov 15, 2003 | 11:51 PM
OatBoy's Avatar
OatBoy
Default Re: How much power is needed to cut tires loose at 50+Mph? (scorp508)
[QUOTE]
yet a top fuel dragster won't break the tires loose with 3,000hp during a good run...
QUOTE]
try almost 7000 hp/ftlb
Old Nov 16, 2003 | 04:25 PM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
I know mine does it with 448rwhp/504rwtq in Drive :D
Old Nov 26, 2003 | 10:26 PM
mistaben's Avatar
mistaben
Default Re: How much power is needed to cut tires loose at 50+Mph? (ALLTHROTTLE&NOBOTTLE)
my 383 TPI with *im guessing* about 380ft lbs of torque at flywheel will light tires at a roll at 30 up to about 38. dont know if that helps. I have 3.07 gears and an automatic right now.
Old Dec 10, 2003 | 08:36 PM
1990CORVETTE's Avatar
1990CORVETTE
Default Re: How much power is needed to cut tires loose at 50+Mph? (mistaben)
Me too with the same set up and it is fun,,, I did it today, a guy I work with that has a 01 Cobra was walking with a gas can,,,,, So I had to let him have it..... :D
Old Nov 16, 2025 | 08:12 PM
JasonArthurTaylor's Avatar
JasonArthurTaylor
1st Gear
Originally Posted by Chuck Harmon
An honest 500rwhp really is more than most people can imagine in a 3200 pound car.
But keep in mind this is for a front-engined RWD car with a low center of gravity. (There's not too much back there holding those rear tires down.)
Old Mar 13, 2026 | 01:14 PM
SteveJewels's Avatar
SteveJewels
[QUOTE=OatBoy;1545663255]
QUOTE]
I'll see your 7,000 and raise you 12,000.
Old Yesterday | 12:52 PM
NORTY's Avatar
NORTY
QUOTE]
Good Lo-Ward, how times have changed....
Nice thread dredge, btw. And from a 1-post Wonder, imagine that!
