C8 Grand Sport Discussion General Grand Sport Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored By:
Sponsored By: Wheel Designers
Grand Sport vs Z06 from rolling start?
Old Today | 04:38 PM
rmiked's Avatar
rmiked
Default Grand Sport vs Z06 from rolling start?
With the higher torque (at lower rpm) and peak values, I wonder how a race would go if from rolling start? Say 20-30 mph to 1/4 mile? Similar weights and the GS should hold rpm well with torque advantage during shifts? The Z06 will stay wound up for sure. These are things I want to see when the GS starts getting tested.
Old Today | 05:02 PM
123sugey's Avatar
123sugey
Dig
Might be a 10.8 car
Old Today | 05:48 PM
LS1LT1's Avatar
LS1LT1
I think it could be somewhat close for a bit with the Z06 steadily pulling away from 75mph+ on.
Old Today | 05:53 PM
LS1LT1's Avatar
LS1LT1
Originally Posted by 123sugey
Might be a 10.8 car
My guess is even slightly quicker than that. In ideal (well-prepped near sea-level track, good air etc.) conditions, I think a bone stock Grand Sport coupe 1LT might even run a high 10.6 at over 126mph.
Old Today | 06:38 PM
24/Eray's Avatar
24/Eray
More interested in the SR vs GS et/mph the SR is going to be faster. Chevy will advertise the GS but you watch. Same everything even gear ratios.
Old Today | 06:53 PM
Over-Rev's Avatar
Over-Rev
I just posted these charts in another thread, look at the torque split between the Z06 and the GS at 3,000 rpms. It’s around 175 lb-ft. That’s a massive amount of torque AND hp in favor of the GS.
From a low roll or off the stoplight, not wound up in launch mode, just normal driving, on a short burst, low rpms, the GS should walk from the Z06 easily. Same weight, same gearing, massive increase in torque, massive increase in HP at low rpms.
Roll racing? Z06 has the win easily. If I had to guess official numbers for the GS I’d say 125 mph traps official (Z06 gearing definitely will help). Z06 has hit 135 in good air on the fast list, and is listed at 131 on Chevy’s website.
In the end it’s power to weight (a=Fm), you can’t beat Newton. Z06 has 135 hp over the GS on the top end. The GS has the power advantage at the low end so if you’re in that range you’re taking a Z06 down. On a road course the Z06 is in its element and will easily put the GS down.
On the drag strip the Z06 still wins because you’re sitting in the Z06’s power band for the entire run. Now when you start factoring in higher gears, rolling starts, shorter runs, the GS will be pound for pound be a challenge for the Z06.
To Grand Sport vs Z06 from rolling start?
