Is my control arm bent?
Old Yesterday | 05:38 PM
Vox Machina's Avatar
Vox Machina
Default Is my control arm bent?
So my (previously wrecked) c5 has been getting a suspension rebuild, which has included some vansteel delrin bushings. Went to go install the front upper control arms, and the drivers side is waaaay off.
This a sign that the arm is bent? If I lay it on the floor it rocks as though the rear-ward arm is bent upwards, and I can definitely see the bushings arent on the same plane. Just want to get yalls opinions before I spend money on another one.
Old Yesterday | 06:24 PM
helga203's Avatar
helga203
What happened to where you would thing it got damaged??
Old Yesterday | 06:27 PM
Vox Machina
The car was wrecked when I bought it. Went offroad at highway speeds, took out the front cradle and spring so I wouldnt be surprised if it was hit hard enough to bend it.
Old Yesterday | 07:09 PM
Ltngdrvr's Avatar
Ltngdrvr
Can't tell just by looking, no apparent bend compared to the arm on my car.
Old Yesterday | 07:18 PM
Vox Machina
Can definitely see the bolt holes are on a different plane. And i can "rock" the control arm laying on the ground by pushing down where the balljoint goes.
Im fairly certain its bent
Old Yesterday | 09:14 PM
Ltngdrvr's Avatar
Ltngdrvr
Get yourself a new arm then, or a good used one from salvage.
To Is my control arm bent?
