C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
Tune Question, please educate me
Old 01-05-2017, 08:51 PM
mfquinn
mfquinn's Avatar
Default Tune Question, please educate me
I had a TS stage 3 cam installed and a tune done. For the most part I am satisfied with the ride quality but need help with the following
about every third time I engage the clutch as I'm coming to a stop light I get an RPM surge to about 1400 then it drops back to idle which is at about 850. Is this to be expected?
every once in awhile at idle it will drop down to about 500 and feel as if it almost wants to shut off. Is this to be expected?
thank you for your time and help
Old 01-06-2017, 12:33 PM
schpenxel
schpenxel's Avatar
Received 1,194 Likes on 1,053 Posts
St. Jude Donor '15
No, shouldn't be like that IMO. Probably needs some work on min airflow and/or some of the idle adapt spark tables
Old 05-23-2017, 07:55 AM
scottg
scottg's Avatar
Have the same problem only mine will drop down to 200 rpm. All happened after cam was installed. Almost impossible to back up on a incline without it wanting to kill when you let out the clutch. Did you fix the problem ? If so what caused it. Thanks
Old 05-23-2017, 10:30 AM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
Min airflow.
Old 05-23-2017, 07:58 PM
scottg
scottg's Avatar
Originally Posted by schpenxel
Min airflow.
Thanks buddy
Tuner has tryed 3 times because I complained about it. Mine is 2008 base model. Would I benefit with a zr1 wide band sensor vs the stock one on the car? I think you have seen my mod changes to my engine. Just not as crazy as Sammy
Old 05-23-2017, 07:59 PM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
Zr1 doesn't have a wideband o2 sensor. I wish they did
There also some max throttle opening at idle settings that sometimes get set too low. If that's too low then min airflow won't be able to go above whatever that value is, I've seen that happen
Old 05-23-2017, 08:08 PM
scottg
scottg's Avatar
Thanks schpenxel
It also goes down to 200 rpms when i'am going 60mph and put the clutch in and brake the car not hard and it will go down to 200 and then like it catches itself and goes back up to 850 rpms.
Old 05-23-2017, 09:40 PM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
Yeah that's classic min airflow issue IMO. Think of it as a throttle set screw on a carb, if you're familiar with those. That's about the best comparison I have
scottg (05-24-2017)
To Tune Question, please educate me
Quick Reply: Tune Question, please educate me
