C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Vortech Supercharger Oil
Old Jun 4, 2026 | 01:48 PM
Pettrix's Avatar
Pettrix
Default Vortech Supercharger Oil
For the self-contained Vortech supercharger units. The 40 ounces of oil in the unit. Can one use Royal Purple Synthetic Automatic Trans Fluid?
Old Yesterday | 12:20 PM
DarkC-6's Avatar
DarkC-6
I wouldn't. Use of any oil other than what Vortech specifies will void your warranty. If you're out of warranty, I still wouldn't risk it. What makes you think this is equivalent?
Old Yesterday | 12:26 PM
Pettrix's Avatar
Pettrix
Warranty has been long discontinued. The Vortech fluid smells and looks like Royal Purple trans fluid. They are identical to looks, flow, smell, touch and taste. I believe there are some forum posts about this which others have claimed Vortech just uses the Royal Purple ATF and puts their label on it for supercharger oil.
Old Yesterday | 04:53 PM
shadetree73's Avatar
shadetree73
Cruising
I was curious myself....
Google says....
AI OverviewThe most popular and chemically equivalent alternative to Vortech V-3 supercharger oil is Mobil Jet Oil II (a synthetic gas turbine engine lubricant). Both fluids share a very similar light, synthetic ester-based viscosity designed to withstand the extreme rotational speeds and thermal loads of supercharger gearboxes.
  • Mobil Jet Oil II: Widely recognized in automotive forums as the direct equivalent to Vortech’s proprietary oil. It is typically much cheaper and easier to buy in bulk.
  • Royal Purple Synchromax: A high-performance synthetic manual transmission fluid often used as a substitute in self-contained superchargers.
  • ACDelco Synthetic Supercharger Oil: While formulated for GM/Eaton superchargers, it serves as an excellent lightweight synthetic alternative in a pinch
To Vortech Supercharger Oil
