C7 Corvette: Secrets of the C7
Learn how this seventh-generation vehicle stacks up against previous model years.
This article applies to the C7 Corvette (2014-current).
Sixty years on the road, the Chevrolet Corvette is a remarkable sports car with impressive performance specs across the various model years. None more impressive, though, is the C7 Corvette, the newest generation of the Corvette family to kickoff in 2014. The C7 generation is America's super car, equipped with patented 'smart materials' designed to deliver precision and high-end performance on the street and track. The interior features exquisite leather upholstery and carbon-fiber, micro-suede and aluminum appointments for a luxurious look and feel. Read on to learn more about the C7 Corvette.
Component Breakdown
Shape Memory Wire
The C7 is manufactured with a 'smart material' wire that adjusts cabin pressure and temperature based on an electrical current that automatically manipulates the lever that controls the vent. The vent opens to reduce cabin pressure and closes to maintain it for the most comfortable ride.
Small-block V-8 Engine
The C7 is capable of reaching nearly 30 miles per gallon when driven in Eco mode, with the help of cylinder deactivation ("Active Fuel Management") which allows the car to run on 4 cylinders in low speed acceleration and cruising. The C7 benefits from a thoroughly reworked and well-designed small block V-8 cylinder engine that relies on an advanced combustion process, aided with variable valve timing and direct fuel injection to optimize performance.
Precision Tires with Asymmetrical Sidewalls
The C7 features tires with asymmetrical sidewalls to increase handling when accelerating to top speeds or hard cornering, offering a smoother, bolder experience on the street or track. Durable construction and increased thickness (3 mm) complements the tire's improved tread components, which feature 150 different constituents.
Scheduled Maintenance
Inspect wear items, such as brakes, rotors and tires, according to the manufacturer's suggested service schedule. Check the oil life remaining on the DIC to determine when new engine oil is needed.
Common Questions
How much distance is there between the C6 and C7?
The C7 was designed with a directed effort to set the back end of the vehicle apart from previous generations. In particular, the C6 features the same dual element lamps, center license plate and low exhaust as previous generations. The C7 features a unique LED, indirect-lit signature that signifies a new direction in style and design for the Corvette.
Does the C7 feature a cross flag hood emblem?
The C7 features an emblem on the hood liner that sets this speed machine apart from other sports cars and previous Corvette generations.
What makes the C7 a top pick among other sports cars on the market today?
The C7 features strong brake performance, incredible track capability, top fuel economy and high-end acceleration for a powerful ride.
Common Issues
Rattling sound in the torque tube
Replace as the torque tube is most likely bent or damaged.
Creaking sound emanating from dash pads
Generally speaking, the C7 offers a comfortable ride with a solid feel. If a creaking sound is present when driving over uneven ground, it is not likely that you will need to replace the vehicle's existing dash pads.
Problems with navigation system
Reset the navigation system by hand, using the owner's manual. If the problem persists, have the dealer troubleshoot the system's configuration.
Related Discussions
- Little Known Features - CorvetteForum.com
- C7 Owner's Perspective - CorvetteForum.com
