Corvette: How to Install Front License Plate Bracket
While sport cars appear aesthetically pleasing without a front plate, it is against the law to not have one mounted. Don't waste money with a simple installation and install it yourself.
This article applies to the Corvette C5 (1997-2004), C6 (2005-2013), and C7 (2014-2015).
It's hard to affix anything—other than an upgraded component—to your beloved sport vehicle. However, in many states it is required by law to mount a front license plate to your vehicle. Fortunately, there are a few good options in the department of front license plate brackets. This DIY guide will cover the Top Flight Reproductions license plate installation.
Materials Needed
- Alcohol wipes
- 4mm Allen key
- 10mm open end wrench
- Phillips head screwdriver
Step 1 – Clean mounting areas
This bracket is adhered to the bumper via strong adhesive. It is important to clean and dry the mating surface before mounting the bracket. Using alcohol wipes, clean the underside of the front bumper where the bracket will be mounted.
Pro Tip
You can also use soap and water.
Step 2 – Test fit
Without removing the protective film, the bracket should be placed against the bumper to test the fit. To do this, align the center of the bracket with the center of the bumper.
Step 3 – Affix mounting bracket to bumper
Once you've practiced fitting and centering the bracket, it can be secured to the vehicle. Remove the adhesive backing. Then, carefully press the bracket to the underside on top of the front bumper. Slowly apply pressure, so the bracket makes good contact with the underside of the bumper. Remove wing nuts from under the mounting bracket to release license plate bracket.
Step 4 – Install license plate to bracket
The bracket kit will come with an assortment of nuts and screws. Mount your license plate to the bracket with provided screws and nuts. Then, secure the license plate and bracket to mounting bracket with wing nuts.
Pro Tip
If you have a GM pre-painted "colored frame," this can now be installed on top of the license plate and bracket with screws and nuts.
Featured Video: Carbon Fiber Removable License Plate Bracket
Related Discussion and Sites
- Top Flight Reproductions License Plate Bracket - CorvetteForum
- Top Flight Reproductions Install Guide- TopFlightRepro.com
- RPM Carbon Fiber Installation Instructions - RPMComposites.com
