13 Secrets of the Corvette
Do you know these secrets?
There are many amazing features immediately noticeable in your Corvette, but have you ever wondered about the not-so-obvious possibilities just waiting to be discovered? Here are a variety of secrets about the C4, C5, C6 and C7 Corvette.
1. C6 Glove Box Start
Another way to start the C6 is by placing the key fob in the hidden receptacle within the glove box, on the left-hand side.
2. C5 Oil Life Reset
On the C5, you can actually reset the car’s oil life by pumping the gas pedal three times. The engine must not be running while doing this.
3. C7 Radio Controls
On the C7 Stingray, you can pause and rewind radio stations.
4. Shake to Unlock
The following applies to all models that have the passive entry feature. If you happen to accidentally lock your keys in the car, simply wait a few minutes and then use your arms/body to shake the car. This will unlock the car!
5. C6 Brake Ducts
The C6 has front and rear brake cooling ducts that bring air from high pressure areas to low pressure areas where the brakes are.
6. Let There Be Light
With the engine off, opening the glove box automatically turns on interior lighting in the C5.
7. C4 Cinch Button
On the C4 seat belts there is a cinch button, which, when pushed, will tighten the belt around the lap to hold you in place when driving hard.
8. C7 'Smart Material'
The C7 features a heat-activated alloy wire that uses a vent to close the trunk lid more easily. This wire replaced the heavy motorized part.
9. C4 Handle Lights
In the C4 (model years ‘84-’89), there are lights above the door panel handles that turn on when you press in on the forward edge.
10. C5 Aux Power
Once you shut off the engine of a C5, you have 20 minutes of auxiliary power remaining.
11. Hidden Key Hatch
If the battery is dead on the C6/C7, there is a hidden key in the key fob that can be used to access the rear hatch via a keyhole.
12. C4 Hidden Armrest Pockets
In ‘94-’96 C4 models, the armrest on the door panel flips open to reveal a hidden map pocket.
13. C7 Hidden Stingray
Open the rear hatch on the C7 Stingray and move to the front of the car. Looking back towards the hatch, you’ll see that it looks like a stingray!
Do you know of more secrets you want to share, or just share your opinions, click right here.
For information on maintenance and repairs, check out our do-it-yourself technical articles at CorvetteForum.com/how-tos/.
