5 Rumored Features of the 2018 Corvette ZR1
There has been a lot of rumors regarding the new and improved 2018 Corvette ZR1, here's what we know.
1. Mid-Engine
A mid-engine platform is perhaps the biggest rumor that is floating around. There have been talks that the new Corvette will move the engine from the front of the vehicle to near the middle. This hasn't been confirmed yet, but if it ends up being true, the new Corvette will be faster, look different, and it should handle even better. The cabin will be pushed forward to make room for the engine, as well as to assist with weight distribution.
>>Join the conversation on the 2018 ZR1 rumors right here in Corvette Forum.
2. Transmission Options
Another hot topic is, choosing between transmissions. The new Corvette is rumored to use a seven-speed dual clutch manual gearbox or a 10-speed automatic transmission as an option. From the seven gears, the top three of them are overdrives; this new transmission should be able to handle 9,000 rpm and 664 lb-ft of torque respectively.
3. Price
The issue with most people is that if Corvette does indeed use a mid-engine, the price has to go up. The prices for the mid-engine Corvettes will start at $80,000, which will then escalate rapidly. The current price tag on the Corvette Stingray starts at $55,000, so you can see why this could be an issue.
4. Turbocharged V6
For the people that don't want to spend a hefty $80,000, there are talks that Corvette will be offering a smaller engine, which is a turbocharged six-cylinder engine. If this rumor is true, then numerous people will still be able to own a Corvette without breaking the bank. This would most likely not happen as there is no reason at all to cut into the sales of the ZL1 Camaro.
5. Hybrid
We don't know what's wilder, the mid-engine, the Hybrid option, or both together. There have been reports that a Hybrid version of the Corvette also could be in the works. The previous GM product executive claimed that a mid-engine configuration could use a small battery and an electric motor, which will tremendously decrease the fuel consumption and allow for all-wheel drive. If GM does decide to add hybrid batteries to the C8 then the ZR1 would join the ranks of other supercars from Porsche, Ferrari, and Mclaren who wish to pull every ounce of power out of their car as possible.
For information on maintenance and repairs of your C5, C6 or C7, visit our How-To section by clicking here.
