Daily Slideshow: Z06 Corvette Has a Night Out in Tokyo
Dino Dalle Carbonare's Z06 Corvette takes an evening "stroll" through some of Tokyo's most famous roadways.
Lost?
You may be surprised to see a Corvette Z06 cruising around Japan. I mean come on, there's nothing more American than a Corvette! Somehow it does not look out of place though. Dino Dalle Carbonare is an author at Speedhunters and clearly a big fan of the Z06. When you hear the specs on this car, you'll understand why you might find it pretty much anywhere.
>>Join the conversation about this Z06 going for a night out in Tokyo right here in Corvette Forum.
Sticking out Like a Sore Thumb
The bright yellow on this 'Vette makes it stand out drastically, in addition to its low stance and aggressive lines. It appears as a wolf among sheep in this quiet parking garage in Tokyo, even when flanked by Godzillas...
The Numbers
The 2015 Corvette Z06 sports a supercharged 6.2 liter V8. That's producing 650 horsepower and 650 ft-lbs of torque at the wheels. If you opt for the "performance package," Chevy will add on Michelin pilot sport cups, adjustable aero pieces, and carbon-ceramic brakes as well.
Rainy Night
How fitting is it that the one night Dino gets to test drive this car, it's raining? With that much power and a manual transmission, wet roads can be your best friend or your worst enemy. Luckily Mr. Carbonare was able to keep this powerful Z06 glued to the road.
A Look Inside
The interior of this Corvette is quite simple and intuitive. Dino points out that the materials seem to be adequate for the money your paying for this car. By the way, the base model for this Corvette will set you back about 80,000 dollars. The Z06 also features a digital display in the center of the speedometer that offers a wide range of customization.
Coming and Going
The backside of this Z06 is mean looking, there's no denying that. It almost appears to be mocking you as it effortlessly passes you on the freeway. There is no doubt that this yellow 'Vette turned heads in Tokyo.
For help with your maintenance and repair projects, please visit our how-to section in the forum.
