Royal Purple’s Synchromax Fluid Is Perfect for Your Manual Transmission
Your transmission puts up with a lot of abuse. Even though your manual transmission was built tough, over time, things like the synchros can go bad. Proper maintenance can add years of trouble-free service, and for your transmission fluid flush, Royal Purple has announced Synchromax. Synchromax is a synthetic high-performance transmission fluid, gear fluid for transfer cases, and fluid for motorcycle gearboxes. Synerlec® synthetic additives ensure that added heat provides even greater protection. The harder you work your transmission, the harder Synchromax works to protect it. Synchromax works for any manual transmission that calls for automotive transmission fluid.
Protection of transmission components is not just limited to lubrication. Reducing heat is also critical to transmission performance, which is a byproduct of superior lubrication. Preventing corrosion and oxidation are also properties of Synchromax, with one other added benefit we can all enjoy: lower parasitic loss means more power goes to the ground, and that means you go faster. Other benefits include smoother shifting and lower gear noise.
Royal Purple Synchromax is available at most national auto parts stores. You can also find it on Royal Purple’s website.
