Possible JL Audio stealthbox upgrade?
I have a JL Audio stealthbox in my 2006 C6 with the 10W3V2-D2 driver that came with it, any one know if a 10W6V2-D4 will swap out, and, if so, will there be a noticeable improvement in bass? I am powering the sub with a JL 500/1 amp. Plan to call JL tomorrow if no definitive answers from the Forum. Thanks in advance.
Purely from a physical size perspective, I'm pretty sure it won't work. The W6 is over an inch deeper, and the basket (frame) has almost no taper,compared to the W3.
1 Post
The only practical option for more significantly more bass output vs what you have is to get a bigger sub. Swapping your 10" 4ohm for another 10" 2ohm might help some, but it's probably not worth it. The JL 13" slim sub and a new enclosure won't be a cheap upgrade but it will hit considerably deeper/louder vs a 10". The slim sub has very low airspace requirements, but it will be more power hungry. I'm planning on using one of these in my C5 a little later, perhaps when the price falls a bit more.
Also, if your amp is not fed with at least 4 gauge hot/ground cables, it might be starved for power.
Thank you for your responses. I called JL Audio tech support and was told "it might not fit because the 6 is an inch deeper, but then again it might fit just fine". I had my driver out and think an inch deeper would not be a problem, could make an inch thick ring to put between driver and enclosure and it would definitely fit. But not sure if the new combination would sound better, could easily sound worse. For around $290, it's not worth it to me. Really like the 13TW5 ($390), but would lose what little space is available in the hatch area.
Correctamundo, or, if they do, and you know they do, they aren't saying. Mark, do you have any ideas for pumping up the base with the JL stealthbox? Thanks.
Pretty much the same response you'd get from GM if you asked about adding the HUD to a 1LT Corvette.
Playing with the settings is really all you can do. If your hu or amp have bass boost, try adjusting it up a bit, if not try tweaking the eq. Maybe even increase the gain on the sub channels of your amp.
Former Vendor
There are far more musical subs than what they offer, I have replaced a few with Arc subs and had much better results.
If me, I would sell the whole thing, get a Baltic Birch Plywood enclosure made and put a very good 10 or possibly 12 if you want even more bass.
Just my 43 years of experience 2 cents input
Rick
Rick
Thanks everyone. I tinkered with the adjustments (thanks Mark) to no avail. So I ordered a JL Audio 13TW5-3 (thanks Gadget01) and I am working on the enclosure.
1 Post
You're welcome- however, my recommendation is a little bit theoretical since I don't already have one. I'm working on making a Polk 12" work out as a carryover from my previous vehicle and well, the JL isn't exactly a low-budget option. I'm convinced you'll be reasonably satisfied with the TW5, but if for some reason you're not, I would definitely consider buying it from you. Curious to see how your new enclosure develops.
