FS: JL Audio 500/5 (5 Channel Amplifier)
NCM Bash 2008-2018
Location: Granby, MA Talladega Super Speedway Vettes 4 Vets Ambassador
Middle TN Events Coordinator
Cruise-In 1, 3, 9. 10 & 11 Veteran
I have for sale a used JL Audio 500/5 amplifier.
The good: It it a very clean and powerful 5 channel amp! Run your whole system off of it or do like me and just use it to power your sub(s) and a pair or pairs of tweeters. Run your main front and rear speakers off your head units power. Provides plenty of options to tweak the sound to your liking. Plenty of wattage to power a stealthbox sub or dual subs. Sounds incredible.
The bad: The 2 front channels when I first hooked it up had an intermittent noise going on with them. Sounded like music distorting and fading out. The following day the noise went away. It's been sitting for about 2 weeks. I had it running last week and again didn't hear it. Not sure why. So be it noted. Might be something...might be nothing at all. The rear channels and the sub channel work perfectly. I have marked the price down accordingly just because of this. Again could be nothing at all but wanted to disclose it.
Etched and painted lightning bolt pattern on the face.
Amp will fit on the back wall of a C5 Corvette.
Any questions feel free to ask.
Specifications:
Front Channels: 100W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
Rear Channels: 25W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
Subwoofer Channel: 250W RMS @ 1.5 ohm-4 ohm (11V-14.5V)
THD at Rated Power: <0.03% @ 4 ohm (F&R), <0.05% @ 4 ohm (Sub)
S/N Ratio* (F&R): >108.5 dB below rated power
S/N Ratio* (Sub): >95 dB below rated power
Frequency Response (front and rear): 5 Hz-30 KHz (+0, -1dB)
Frequency Response (sub channel): 5 Hz-500 Hz (+0, -1dB)
Damping Factor (front and rear): >200 @ 4 ohm/50 Hz
Damping Factor (sub channel): >500 @ 4 ohm/50 Hz
Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
Dimensions: 19.7"L x 9.25"W x 2.36"H
Features:
Differential-Balanced Input Topology: (3 pairs of inputs)
Front Crossover: Fully-variable (50 Hz-5 KHz), selectable-slope BP or HP (12 or 24 dB per octave)
Rear Crossover: fully-variable (50 Hz-5 KHz), selectable-slope HP (12 or 24 dB per octave)
Sub Crossover: fully-variable (40-200 Hz), selectable-slope LP (12 or 24 dB per octave)
Preamp Output: 2-channel (full-range or LP)
Bass EQ: Variable boost up to 15dB. Remote bass boost control optional.
Infrasonic Filter: defeatable 24dB/octave at 30 Hz
Left minus Right Ambience Circuit: ambient effect for rear channels
Front and rear speaker output connections: accept up to 8ga. wire
Dual mono subwoofer output connections: accept up to 8ga. wire
+12V and Ground connections: accept up to 4ga. wire
Price: $145 with FREE SHIPPING ANYWHERE IN THE CONTINENTAL US!!!
This sells anywhere between $200-$400 on ebay right now.
Specifications:
Features:
Pm sent
