2008 c6 base new radio DYI help
Emerging Vendor
Hello ....I'm getting ready to install a pioneer double din radio in a base c6....is there a good dye with photos that can help me through...I have a amp box also that I wish to install...this is a non bose system...and would like to know what interface adaptor I need as well...I have no steering wheel radio controls....Thanks for all your help
If you have OnStar and want to keep it get THIS KIT, if you don't have or do not wish to keep OnStar then get THIS KIT
There are several good DIY threads, most will have more info than you need for your simple install. Look at the sticky threads, and check out this one also.
All you really need to know is how to pull the dash apart. The C2R is almost plug-n-play and the OS2C isn't much harder.
