Question for those who trailer
Those of you who trailer your car to events-did you have any issues with loading your car on the trailer due to lowering? I am considering purchasing a trailer but was concerned with being able to load it. Do you have extra long ramps? Is the rear of the trailer low to the ground? What should I look for when considering purchasing a trailer? Thanks in advance for the help. This forum is definitely A-1 when it comes to people helping people.
I have extra long ramps I made. I bought the metal ends from Harbor Freight or one of those companies, can't remember who. I got two 2"x12"x12' boards and two 8' long metal angle iron pieces from Home Depot. Attach the ends, put the angle iron on the bottom of the boards, and viola, ramps. They work great and they were cheap, but they are not fancy. I think everything cost about $60 or $70.
You must have long ramps to load the car or it will drag on the bottom in the middle.
Dog
Dog
A few things. YOu may find that you may need to raise your car back up to within 1/2 in normal ride height for better suppension travel and car stabilty. at first it is difficult as the car looks too high. Soon enough you will find the car handles far better close to stock ride height.
On the tailer issue YES, haveing extra long ramps does help, plus lifting the tought of the trailer a little heigher.
There are trailers that sitt lower to the groud then others, so look for something like that.
Are you looking for an open or enclosed trailer??
Here is mine with 5 foot alumium ramp extension added to the drop down door.
I've got a 28' with just your standard tail ramp on it and mine works fine. It's a bit lower than stock, but the trailer sits higher than most. If you have ground effects on yours, then you'll most likely need extension ramps, but other than that, I doubt you'll have any issues.
When I had my open trailer, I would also put the rear wheels of the truck on some home-made ramps. That will push the back of the trailer a little lower to the deck and make loading a little easier.
I made my front ground effects removable with 1/4 turn thumb latches, and jack the front of the trailer all the way up when loading/unloading.
Don't use them but longer ramps would help.
Use ramp extensions, aluminium along with thicker bumpers for the doors. A really helpful thing is a winch and the folding tow hooks from Phoenix. They really came in helpful when i blew the engine earlier this year.
I have an open trailer. To ensure the corvette would load I found one where the last 3 feet or so slopes down (I think this is called a "bobtail"). Loading the car is no problem.
My alignment shop recently slightly lowered the car to allow for a more aggressive alignment. After this I discovered the door would no longer open over the trailer fenders. I posted the situation here and got two recommendations:
1) Several folks said they simply attached 2X12's on the left side of the trail (in the tire tracks) to raise the car on that side.
2) Several others indicated the purchased or fabricated a removable left side trailer fender so they could take it off to load/unload and put it on to transport.
I decided to try the easy route first (2X12). I just attached it to the trailer this last weekend and will load the car for the first time this Friday. We'll see how it goes.
Hope this helps.
John
Hope this helps.
John
Hope this helps.
John
Hope this helps.
John
Here is what I got........Hydraulic tilt bed........from http://www.ssitrailers.com/default.html
18' with a 4' dovetail.
What every you get, make sure the DS fender is removeable......
Our C5s are lowere and I put a 2 x 12 3' long on each side so the front ground effects dont get crunched.
More info in my previous thread:
http://forums.corvetteforum.com/show....php?t=1477744
I ended up having to both buy ramps and change the trailer fender to removeable. I bought my 7'10" long by 14" wide aluminum ramps here:
http://www.discountramps.com/auto_ramps.htm
The wider than standard ramp gives a little more room lining up the car.
When you shop for a trailer make sure you can open the driver's door after the car is loaded.
I have a 22.5 foot enclosed trailer for sale, it has the side openning door for the drivers door, the car, lowered C-4, clears by several inches. Don't buy any trailer you cannot load your car.
vettmike
vettmike
