brake fluid-what do you recommend
For road racing applications what brake fluid do you recommend. I am using Wilwood brakes with their E series pads(street/road race pad).
Thanks.
Thanks.
Castrol SRF the best by far. Cheaper because it last longer with less bleeding in between. 65 for a liter but worth evry penny. I went 999 miles no bleed I was used hard and all track miles. It was shot by then but it last a long time.
Most importantly, fresh.
After that, it depends on how hard you're tracking the car. With typical aggressive street pads, most likely any good DOT 3/4 fluid will be OK, as long as it's fresh.
HTH, and have a good one,
Mike
Mike
Thanks. I both street the car and use a couple times per month at track. Any suggestions on how to determine when it's time to replace? Should I let the amount of track miles(or hours) determine?
St. Jude Donor '05-'08
I use ATE Super Blue Racing FLuid. Seems to work fine for me.
If you are not doing much track time I bet you can easily get away with a few times per year. That being said I would watch your fluid at any event and see if it is turning dark. Depending on the event and how hard you brake you could boil the fluid at anytime and then it needs to be replaced ASAP.
I use ATE too. I got used to using it in my European cars.
If you alternate between the blue and the amber (same fluid except the color) you can easily tell once your fluid is flushed.
I haven't had a problem with the ATE fluid, so I'll continue to use it.
Originally Posted by FasterIsBetter
Former Vendor
1 Post
most of our customers have had great results with the PFC "Z-rated" fluid. Dry boiling point is over 550. For the guys that are putting more heat into their brakes, we use Motul 600.
I have found that after each track day if you bleed off 3 full pumps at each bleeder screw and replenish the res with fresh brake fluid that you'll hardly ever have any fluid related brake issues.
1 Post
Cruise-In II Veteran
