Pressure Bleeder
Pressure Bleeder
It's time to step up to a pressure bleeder. I'll be using my air compressor. Any good pressure bleeders out there? I'm looking to do all my GM cars, not just my corvette.
I'll also need the rectangle cover adaptor for my older GM's
Originally Posted by gkmccready
I went for the Motive, which doesn't connect to my compressor, but does everything I want including adaptors for non-GM vehicles.
Been using it for 2 years now, after every weekend at the track. Cheep insurance and no brake problems.
Bleeder is rated at 20 PSI but only needs 10 PSI to make it work. This will keep any issues with "air embolism" to a minimum.
Received 8,928 Likes
Larry,
I use the Motive also. However, mine came with a fixed GM adapter that fits the Corvette. To get what you want you probably would have to get one of the Motive units that come with several adapters.
The Motive works very well and it is very handy to have in the pits since you do not need a compressor to run it.
By the way the BMW Genessee Chapter has its 2007 Watkins Glen dates on the web page. I just signed up for a May 5th Trackmasters open track event so I can get some track time before the BMW ITS the following weekend.
Bill
Bill
Originally Posted by AU N EGL
I made my own cap, with a three way valve to release pressure before removing the cap from the MC
What's your procedure, Tom? Note that I don't put brake fluid in the Motive bottle, only in the MC.
I use mine by not following the directions.
Fluid only in the MC, not the bottle.
Originally Posted by vettmike
I picked up a Motive bleeder several years ago, never did have any luck using it, just made a big mess.
So why the extra valve rather than cracking open the top on the Motive bottle to release the pressure? (Sorry, not trying to be a jerk, just trying to understand)
Kill time. I am not much of a mechanic let alone an engineer. So making that thing work was an acomplishment for me.
vettmike
Golden Eagle - How did you get the cap to properly seal on the Master Cylinder ? I built a similar one to yours but kept losing pressure around the cap seal. Added thicker gaskets, etc, and still could not get it to seal and hold any pressure. Your advise would be appreciated.
