Trailer set up ideas
I just got a new Haulmark 22ft TAG trailer and need some ideas on how to set it up on the inside to fit my needs (mostly track days and time trials, but may start doing some drag racing too). Anybody have suggestions and/or pictures of the inside of their trailers so I can get some ideas?
I like e-track on each side, with bars going across the width of the trailer to support tires. Loads them nicely on both walls, instead of loading just one side. Wheels/tires are the biggest, bulkiest items usually, so everything else can just get crammed in the front.
Make sure you are using a load-leveling hitch, and put ample weight on the tongue for stability. Even if you have a dually, load-leveling bars really help stability and safety.
I've seen those aluminum shoring beams that stretch across the trailer for tires, and that looks like a great idea. Any idea where to buy those beams?
1 Post
This is just the first one that came up on a search. Use the terminology to do your own searches to find the best price
http://www.truckntow.com/pc-11512-14...track-102.aspx
this might sound crazy but go to racingjunk .com or ebay and look at how the millions of trailers for sale/auction are setup.
...redvetracr
PS: I believe that e-track stuff is available from Aeroquip
...redvetracr
Doesn't sound crazy at all. I've been checking Ebay and Racing Junk for a long time looking for a trailer and saw some pretty nice set ups. I am also trying to figure out how I should finish the floor as it is just plywood. I wonder if paint with some kind of sealer would work.
1 Post
Cruise-In II Veteran
I prefer using fixed length steel cables on the front. They are smaller, cheaper (Home Depot, Lowes, etc), and guarantee that the car is in the same place everytime. I also use a load leveling hitch with a sway control and a Tekonsha Prodigy inertial brake control.
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes
Prodigy here, also. I like it. I pull a tag 24 footer that is bare on the inside. In order to fasten things down, one needs to add some tie areas. I made two rails across the front of the trailer using two eight foot 1 x 1/2 inch oak from Lowe's. I got an extra rail to cut up into short blocks. I counter sunk holes in the rails to line up with the metal studs in the trailer behind the plywood wall. I then put a 1 1/2 inch self drilling metal screw through the rail, the spacer block and into the metal stud. I am able to tie everything up front out of the way. I put my extra tires in a stack with a strap through the wheels and behind the rails.
Wells Cargo 24 here. I had a tire rack built by the place I bought the trailer from. They used 1 inch square steel tubing and sized it for 8 tires plus the trailer spare. Decided to put in on the passenger side of the trailer (welded to the trailer's metal studs) so I could still get to the race car door from either the front or the back. Also had it so it folded up flat against the trailer wall when not in use (towing my buddy's antique show cars that werer too tall to put in with the tire rack down.)
Built my own cabinets using Lowes garage stuff plus better latches and hinges to deal with the flexing. Basically a workbench across the front with room underneath on one side for the jack and fuel jugs. The other side had drawers. Hanging cabinets across the upper part of the front wall. I kept my tools in a roller toolbox with good rubber wheels and rolled it between the garage and the trailer, then secured it with lots of tie downs and hooks on the wall, although e track would probably have been a better idea. Also went with ramp extenders like in the pictures above.
Wood floor. It got a little scratched and stained, just touched it up with grey paint.
I skipped the vents in the roof since almost all trailers I have seen eventually leak there when they get old.
This trailer served me well for many years and three different race cars.
Mike
Mike
Having a small 20ft trailer, we had to be a bit more careful on space. Small roll around tool chest bolted to floor, pit pal style door unit on the other side, fuel jug holder. This all clears the nose of the car (even with 4" splitter) nicely, and you can walk in and get to tools if needed. Also cool jack stand holder right by the door. Also have a folding aluminum tire rack on the passenger side wall for rain tires. I'd like to add one overhead cabinet later, for helmets, but this works for now.
Enough room for a pair of bikes using fork mounts bolted to the floor.
Tie down holders (pair) - Summit
Tire Rack - Pit Products
Door caddy - Pit Products
Jack Stand rack - Pit Products
Fuel Jug rack - Summit
Winch - Superwinch 3000lb
Tool cabinet - Lowes
In Floor Storage!!!!!!!! One thing I had done on my old trailer (and also had some built for my new one) is put some storage areas in the floor. The trailer guys simply make a metal box to enclose the cross members and cut a square hole in the floor, add some hinges and a latch and you have some really strong storage space for spare rotors, brakes, etc. My guys charged me about $350 to build them. It's a great space saver!!!!!
I reorganized my tools at home. I put every tool that I would need at the track in my roll a round tool chest. I even found a small air compressor that fits in one of the drawers. I used a couple of the drawers for supplies and misc. hardware. When I load up I just wheel the tool chest onto the trailer and strap it down.
I used E-track to make a tire rack and to strap the tool chest to. E-track is available at my local trailer supply.
OK everyone who replied, thanks for the advise/tips. I got some epoxy garage floor paint from Home Depot and started on the floor, and found the E-track stuff at Pecasus Racing. Will be ordering some of it as well. Any advise on which winch to get. Make and size? Thanks
