Dedicated Race wheels
(I posted this same thread in the "wheels and tires" section and got 0 responses in 2 weeks... figured it might have a better go here)
I have lots of questions but hopefully this thread can help more people than just me...
1. Do most of you that are into racing or HPDE's and have wheels dedicated to track events use smaller than OEM wheels to save on cost?
2. What size do you recommend for a '06 C6 Z51.
OEM
Front - 18 x 8.5
Rear - 19 x 10
3. Does it mess up the speedo?
4. Are all 4 wheels the same size? (All 18's)
5. Do you run without pressure sensors in those wheels?
6. Are most wheels offered by vendors mainly for appearance and not intended for track use?
Any help is greatly appreciated!!!
OEM
Front - 18 x 8.5
Rear - 19 x 10
1. YES
2. 18 all around. 18x10 and 18x12 are popular or 18x9 and 18x11
3. Who has time to look at a speedo ?
4. see #2
5. Nope No senssors, just hit the reset button. Keep your stock C6 wheels in the paddock near where you park
6 YES most wheels by venders are great bling wheels not for track use. CCW makes track dedicated wheels. The CCW Corsair, CCW classic and the new CCW C14. are the C14 and Corsair the same wheel?.
4. see #2
IwntmyZTV,
1. Once you get into it and go to race rubber you really need a separate set of wheels and tires for the track. But if you are just starting off stick with the street tires you will learn car control and other essentials much easier. CCW makes a great light weight wheel that is reasonably inexpensive.
2. Sorry, you will have to ask the expert that one, I run a C4. A good friend ran a FRC a few years ago and ran 18x?? Front and 17x?? Rear (Sorry I can not remember the exact sizes…). He really liked that set up.
3. Depends on how much larger and smaller you go...
4. I would run all the same size if possible so I could rotate the tires to get the most out of them.
5. I would not run with them; it is just going to be a bigger PIA when mounting tires.
6. Depends on the vendor.
There are some great and knowledgeable people on here hopefully someone who runs your generation will chime in and help you out (And correct me if I am wrong )
Daniel
Daniel
As a novice, here are my answers:
1. I use OEM wheels for track & chrome aftermarkets for street driving.
2. Stock sizes.
3. No.
4. I run stock C6 sizes (18" F & 19" R).
5. I have pressure sensors in both sets of wheels that I have, the technology is there so I want it available all the time.
6. I would say it this way....more "visible" vendors sell wheels intended for street than for track use.
2. Stock sizes.
3. No.
Dedicated wheels leads to dedicated rubber, which leads you down the slippery slope of dedicated trailer and tow vehicle, etc.
If you plan on mounting DOT legal-tread rubber on track wheels to drive it to the track, I don't think you'll be gaining enough performance over stock tires to make much of a difference.
I agree with AU N EGL, another vote for CCW. John Purner builds a great wheel, light and strong - I recently spun at the track moving at over 90, impacted the sand hard enough to pop the L/R tire off the bead but barely scratched the wheel, no cracks and still fully serviceable. They're reasonably priced and well worth the money.
And as suggested I'd make whatever conversion is necessary to run 9.5 x 17 wheels all around. Shouldn't be much, and auto-x is all about front grip so the wider tires in front will help a lot.
IwntmyZTV, obviously I have a C5 but I can still try to answer some of your questions.
1) Yes, long term it turns out to be cheaper to run a dedicated set of wheels for tracking your car. Not to mention how much faster (and more fun) race tires are. As such, most of us have dedicated track wheels/tires.
2) You have lots, and lots, and lots of options here. Your budget is a key determining factor. I know of C5 Z06 guys running C6 Z51 brakes with stock 17x9.5 front wheels. I'd assume that means a C6 Z51 can run as small as a 17" wheel. Again, options, options, options.
A set of used, stock C5 Z06 wheels would probably be a great choice (again, assuming they clear the C6 Z51 brake setup which I hear they do... but I'd test it out before shelling out any $). Factory C5 Z06 wheels are strong, (relatively) light and pretty cheap. Especially for track wheels where you don't mind buying a set w/ some curb rash (be sure they are good and straight though). On a set of C5 Z06 wheels you'd want to run a 265-295/40-17 front and 285-315/35-18 rear tire. For HDPE events I'd suggest the Toyo RA1. Hoosiers (A/R6) or Kuhmo (V710) would be faster, but also wear much faster and are generally over-kill for you "average Joe" doing HDPEs. That being said I usually run V710s on my stock Z06 wheels as track day tires, but that's just because I jump on every deal I can find for used, well heat-cycled but plenty of rubber left V710s.
The next step "up" as far as traction would be to buy a set of 4 "ZR1" knock-offs in 17x11 all the way around (you actually want the Grand Sport offset, not ZR1). These are going to be much heavier than the C5 Z06 wheels and stick out a bit. You'd run a 315/35-17 all around with these wheels. I'd suggest this setup more for an AutoX car than a track day car. Honestly the extra front end bite from a 315 vs. the 295 you can run on a C5 Z06 wheel probably isn't worth the weight and aero drag on a road course. For an AutoX it really helps get the car turning in though.
After that I'd recommend a CCW Classic. Now you can go big and save weight. Your sizing is also much less limited. I run 18x11 front 18x12 rear CCW Classics as my AutoX wheels (as I mentioned before I use my stock wheels for road course stuff). I run a 315/30-18 and 335/30-18 Hoosier A6. This setup would clear your brakes no doubt, or most big brake kits if you ever go that route. And would probably be "the fastest" wheel/tire package you could run (A6 for short sessions and if you don't mind buying tires often, or R6 for longer sessions/tire life).
I'd avoid 19s all together for your race wheels, competition tires are still limited and costly.
3 & 5) the C6 guys have answered for you.
4) That's up to you, see 2.
6) CCWs are great wheels and the Classic is a very nice track wheel.
-TJ
Location: DFW This user does not support or recommend the product or service displayed in the ad to the right
On my C6 I run 18X10 front and 18X11 rear CCW corsair with Toyo RA1 275/35/18 Front and 305/35/18 Rear. The CCW will accept the tire pressure sensors and they are a great group to deal with. My setup works great for me and the wheels and tires tuck up in the fenders nicely without any rubbing whatsoever.
John@CCW recommends the Toyo RA1 setup in 18x10+18x11. The CCW C14 is the Corsair. The C10 is the new track wheel coming. The T10 is the street wheel version. You can obviously run better DOT-Rs than the Toyos without issue, and you can run wider wheels if you're willing not to go lock-to-lock on the steering, etc, etc.
