Harness Mounting in Late C4s?
Anyone have pics of a harness mounted in a Late c4? Can we go the the floor in the rear or do we need a harness bar? Any other inventive setups?
So yes, immediatly after posting this I found Hardbars site, and plan on getting a harnessbar.
So that covers the top mounting point, what about the floor(s)?
Does anyone else actually have a harness in their C4 with stock seats?
Chooseing a Harness...
If its just to keep my butt and shoulders in place during autoX and PDX's, who makes a good harness? 3, 5, or 6 point? Why?
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
Gary sells special bolts, with a 6pt harness you wind up using the same points as the stock belt. Both the side straps and the lower (antisubmarine) belts go there. The lower belts go between the seat bottom and back.
Don't put them over the front of the seat.
1) the don't work as anti-submarine belts
2) the belts can cut into your legs
This is a C5, but I've got my C4 rigged the same way.
Since we don't have a hole in our seatback, if you can afford it, get the sternum strap, so the shoulder belts don't spread apart.
Location: If you don't weigh in you don't wrestle Road America
I used the R&D racing bar and it is bolted to where upper seat belt guide goes and where the glass roof stores when not used. I also used the R&D fire extinguisher mounts to mount the sub belts as well as a fire extiguisher on the passanger side. I like the G-force cam locks, you can get the more traditional latch and save a bit but I like the camlock.
Here's a shot of the rear
Sorry the belts are blocking where the harness bar secures to keep from rotating.
and front
The one thing that I would definatly get though would be the Brey/Krause harness mount so you can remove the inner lap belt, I haven't bought the kit yet but it sucks having that thing flap around when you aren't using your harness.
and front
Look at the manufactures suggestions for mounting harnesses.
Normally for shoulder harness it is +/- 5* from shoulder level.
Mounted though seat back holes, not around the seat.
Mounted on two points not one point for two belts.
The bar for mounting the belts should be as close as possible to the back of the seat.
PCA is going to a uniform Harness mounting rules:
"Harness systems
February 5, 2007
Dear National Staff and Region Presidents,
The purpose of this email is to inform you of a change in the Driver's
Education National Standards regarding the use of safety harnesses which will become effective on Jan.1, 2008. The current "Equal Restraint"
Standard states that both the student and instructor shall have the same restraint system.
The problem with this Standard is that it does not define the complete system, in terms of the type of seat to be used with a 5 or 6 point harness.
The new "Harness" Standard (See below) is written to compliment the
"Equal Restraint" Standard and will go into effect January 1, 2008, but a region may adopt the standard earlier.
The new standard states that if a harness system is installed, it must be used in conjunction with a seat with manufacturer supplied routing holes for the shoulder and anti-submarine belts. These routing holes insure that the belts will remain in place when needed. A one piece seat is recommended but not required for it may interfere with the operation of the OEM three piece belt required for street application.
Thank you for your help in implementing this new standard. If you have any questions, please feel free to contact me.
Pete Tremper
National DE Committee Chairman"
FIA standared:
THE INTERNATIONAL SPORTING CODE, Appendix J Article 253, Safety Equipment
http://www.fia.com/resources/documen...pJ_Art_253.pdf
NASA harness system Tech regs
15.5 Driver restraint system
(See diagram at end of section)
1. All vehicles must have a five (5), six (6), or seven (7) point seat belt system. Arm restraints are required in open cars and cars with: Open T-tops, Open Targa tops, missing moon/sun roofs, or glass moon/sun roofs.
2. A five (5) point system consists of a three (3) inch lap belt, two (2) or three (3) inch shoulder belts, and a two (2) inch anti-submarine strap.
3. A six (6) point system is recommended for cars where the driver is seated in an upright (to thirty (30) degrees) or a semi-reclining position. It consists of two (2) anti-submarine belts in addition to lap and shoulder belts. Note: Current FIA Approved belt sets with two (2) inch lap belts are acceptable with the six (6) point system.
4. A seven (7) point system is recommended for seats with more than thirty (30) degrees of incline. Note: Current FIA Approved belt sets with two (2) inch lap belts are acceptable with the seven (7) point system.
5. The material of all straps should be Nylon or polyester, and in new or perfect condition. The buckles should be metal quick release. There should be a
common release for all belts. [Note: Certain Momo brand belts were recalled by the manufacturer. These are NOT suitable for racing.]
6. The shoulder harness shall be mounted behind the driver and above a line drawn downward from the shoulder point at an angle of no more than twenty (20) degrees with the horizontal.
7. The seat, seat holes, and attachments to the seat are not permissible “harness
guides” for compliance with the angle requirement. Only specific harness guide bars, or parts of the chassis or the cage are allowed to be used for this purpose.
The guide bar, if used, should not present a sharp edge to the belt. It should provide as much area of support as possible to distribute the load.
8. Only separate shoulder straps are permitted. “H” type belts are allowed. “Y” type belts are not allowed. Each shoulder strap must have an independent mounting point.
9. All mounting hardware should be SAE grade five (5) or better. Large diameter mounting washers should be used to spread the load. Bolting through floor panels etc. is not acceptable without required washers.
10. All belts should meet at least one of the following:
A) SFI Specification 16.1 or 16.5 (for use with HANS only) and shall bear a dated label of no more than two (2) years old. At least one date label is required on belt sets.
B) A restraint system meeting FIA spec #8853/1985, 8853/98, or D-###.T/98,
including amendment 1/92 may be used. FIA certified belts have a label that shows an expiration date. The belts cannot be used past December 31st of the year shown on the label. At least one date label is required on belt sets.
11. All drivers should take care to ensure that their belts are properly worn, adjusted, and latched. “Cam-lock” type belts can be subject to inadvertent release,
should the driver fail to ensure that they are properly latched.
12. Any driver involved in a high impact crash shall send all of their safety belts back to the manufacturer for inspection, re-webbing if necessary, and re-certification
before they may be used again in competition. Proof of re-certification is the driver’s responsibility.
13. All belts should be threaded to the manufacturer’s instructions. An example of one type of threading instruction set appears at end of this section.
"Harness systems
February 5, 2007
Pete Tremper
FIA standared:
If you're interested I have an AS&M bar with a Schroth 6 pt setup I'll let go used if you're interested
http://forums.corvetteforum.com/show....php?t=1494188
There are many good harness setups out there but I would only recommend 6 pt, 4 has little anti-sub protection and 5 will kill your manhood! I have found 6 to be much more comfortable and doesn't require any seat mods (especially if you've got stock seats).
5 point with race seat, 6 point is a better harness and saves the family jewls
When setting up harness and seats, dont forget to have an exit stratgey too. Just like on the track
SHould be able to get out of your harness system, open the door and out of your car in under 10 seconds.
I found it to be effective afterwards.
I have tried both the 5 and the 6 point belts and I like the 5 point better. I would rather have the junk pushed down a little, instead of being pinched in the 6 points.
Now I've only worn 6 points in C5's with the Brey Krause clip in belts, but I perfer the trusty old 5 point. It might have been better if I would have had more adjustment. I'm a bigger guy 6' 240lbs so I may have just ran out of adjustment on the 6 points.
Just my $.02
Just my $.02
I find I sit on the two sub belts such that they're on the low parts of my "cheeks" so any force will go over the upper back part of both legs, rather than one point in the crotch.
When looking at a 6 point make sure that the 6 point that you get doesn't have adjusters that would sit under you butt. This can quite literaly become a pain in the @$$. I believe Schroth had adjusters there but Sabelt didn't.
