Trailer - How to get lowered vette on!
How are you guys getting your lowered Vettes onto your trailers? Are you making longer ramps or what? Any pictures?
Thanks,
Thanks,
Great picture and you have the correct angle to get your car in your trailer. I have an open trailer and it even have a dovetail but the ramps are only 5 foot.
You must have at least 10 or 12 feet. That would solve my problem if I could find a way to add ramps to the trailers ramps? I currently use 2x10's but they tend to move so are sort of dangerous.
This is probably not in the least bit helpful to you right now since you already have a trailer. But I got tired of screwing around with ramps and got a roll back trailer. Z06 loads up just fine with only the rubber spoiler bending a little as I approach the trailer.
http://www.kiwikload.com
http://www.texasrollback.net
So, if you are at all in the position of looking at getting another trailer you should check them out.
Someone else had a link to a company that made aluminum ramp extensions. Maybe they will post here.
Good luck,
Good luck,
Hope that helps.
Received 8,930 Likes
Bill
You can do the same thing by getting a welder to make a similar pair of ramps for you out of some angle iron. Probably can get it done for less than $250. Use your current ramps as the bridge to the new ramps. Just make sure the trailer can't tilt backwards before you drive onto the bridge ramps. While you are at it have the welder add a couple of brackets to store the new ramps under the back end of the trailer.
Bill
Bill
Getting Vette onto Trailer - Pictures
Everyone, thanks for all the input. I currently use a 2x4 to get my car on the trailer ramps but with recent suspension work the car needs to get higher to get onto the ramps. After reviewing everyone’s input I was in Sam’s Club yesterday and saw these ramps that I hope will fix the problem. If this get’s the car up high enough the next issue will be to try to tie them into the trailers ramps so I will have a smooth transition unto the trailer. By the way these ramps are $55 + tax at Sam’s club so it is probably the same cost as making wood ramps and easier to carry around/store.A picture is worth a thousand words so I have included pictures of what I bought and the two ways I can possibly use these ramps to help get onto a trailer.
1st way to try to use ramps
Box
Ramp laid flat out
Flat ramp under car
2nd way to try to use ramps
Ramp double up partially under car
Ramp double up under car – Notice air dam
Ramp double up all the way under car – Air dam bends back
Side view of ramps
The goal is to get the car onto the trailer ramps and trailer without damaging the 1. Paint 2. Air dam
Next I will pull the trailer out and experiment with moving the car onto the trailer. Unfortunately this will have to wait a week or so because as nice as it is today (75 degrees) Tuesday, the temperature will drop to around 35 tomorrow and snow Wednesday night into Thursday and it is suppose to stay cold through the weekend.
Perils of living up north.
Appreciate all your thoughts and inputs on how to help make this work.
USRobo
Box
Ramp laid flat out
Flat ramp under car
Side view of ramps
USRobo
