Pros and Cons of Having the Rev Limiter Raised?
I'm currently having my stock C5 Z06 LS6 engined tuned and was offered the option of having my rev limiter raised. What are the pros and cons of doing so? What's the most you would raise it by?
Thank you!
Anita
Thank you!
Anita
I believe he was thinking to only go about 500 up. The main positive I could see is that it would save me from maybe having to shift into 5th, for teeny bits of time on track in places and potentially avoid a "money shift" (the kissin' cousin of the "big bang" ). Would it really be that much harder on an engine to run the revs higher for short times? (I know you don't know my driving style, but I do love my revs).
I don't reall bother even shifting at my redline unless a big motor is what I am running against. I try to do 6500. Squential shift light would be worth more on track than bumping the revs with no downside.
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,086 Likes
With a stock cam the only gain I could possibly see would be saving you a shift in an awkward turn at a track you race at regularly. Which at that point I would change my entry or something.
The power will fall off by raising the limited so there is not a power gain, the rest of the engine can handle the revs fine, except for the valve springs that were not designed for that. So personally I would leave it at or near stock.
CI 3-5-6-7-8 Veteran
My car made power all the way to 7k w/ it leveling off after 6600, but not dropping.
Per GM RAcing and Katech endurance testing:
6500rpm for 97-2000 rod bolts
6900rpm for 2001-up engine rod bolts.
In theory, if you stay below the above limits, your engine would run "forever" on a loaded dyno. Of course, "forever" is a relative term in durability testing!
***My WC engines ran easily up to 7500rpm with stock intake and TB. If you have the valvetrain lift to suck enough air in, that is***
I had my G5X3 car with 921 Comp springs set up at 6800. I also had my stock car set up to 6800 for a couple seasons before the 921's. I would RARELY shift at these point because the stock cam is NOT making power...
But, there are DEFINATELY circumstances on certain tracks where you are just a redline, but still accelerating towards a corner and need to make a decision to upshift for 3 seconds, back off, or bump off the limiter. I had this problem at Watkins Glen going into the toe of the boot. The extra 2000 rpm was EXACTLY what I need to keep me accelerating. While I was not making lots of power, I was still accelerating and at least not coasting into the corner.
So, I understand why you want to do this...it has nothing to do with power, but releaving some uneccessary shifting. I can't tell you nothing bad will happen, BUT I did run a stock motor at this limit for 2 years...BUT I ONLY ran it to that RPM when I absolutely had to such as the toe of the boot at WG.
But, there are DEFINATELY circumstances on certain tracks where you are just a redline, but still accelerating towards a corner and need to make a decision to upshift for 3 seconds, back off, or bump off the limiter. I had this problem at Watkins Glen going into the toe of the boot. The extra 2000 rpm was EXACTLY what I need to keep me accelerating. While I was not making lots of power, I was still accelerating and at least not coasting into the corner..
Video here:
http://www.youtube.com/watch?v=7QowaUEaL_A
But, even if you bump the rev limiter up 200 (I believe the 2000 referenced above is a typo), you'll still have courses where you'll be tapping the limiter.
Have a good one,
Mike
Former Vendor
I am going to be the first to say the chains can't hold up to rpm at all. Many motors come in here with flat out broke chains, and cam bolts falling out.
Randy
Randy
My 04 Z06---that I run in ASP now----had the limiter raised to 7000 rpm----headers intake etc. By Danny Popp. His car had the limiter raised to 7300.
I am not a "Master Vette mechanic", that has his own seperate area, at a GM dealer. So I asked Danny to set mine to 7000 rpm. No problems at all since June of 05-----and I have probably run at least 50 autox's-------banging the crap out of the limiter in 1st and 2nd----every now and again.
7000 rpm no worries IMHO
David
Founder GIANT FUNGUS RACING
David
Received 8,930 Likes
Bill
Former Vendor
Guys and Gals,
Please try something the next time you are out on the track.
1st, running the crap out of her. Check lap times
2nd, short shift for a couple laps. Check lap times
Auto-x I bet would be faster banging it off the limiter, maybe
Road-race My money would be on the short shifter.
Randy
Randy
Guys and Gals,
Randy
Randy
I wouldn't be surprised if your right . Next time (~ 3weeks) I'm at Road America I'll try it.
Dan
Randy,
That's my theory as well. This last event was the first one where I found myself riding the rev limiter about halfway down the straight, just waiting, waiting, waiting for the next corner.
On this course from my best 1st gear only run to my first run shifting I dropped 1.1xx seconds, and ended up my best 1-2 run being 3.6 seconds faster. Frankly, I was astonished.
Justin, I might just take you up on that. I just swapped out the stock valve springs for yellow Z06 springs, so I think that would be a safe thing to do.
Randy, do you think a 200-300 bump with new valve springs would be OK on an engine with 150,000 miles on it?
Thanks for the help, and have a good one,
Mike
Originally Posted by jtkeller
we can bump your rev limiter up in a few seconds with my hptuners if you want...
Mike
