Upgraded Brake Calipers
I've looked at Wilwood, Brembo, Baer and at my wallet and they don't seem to match. Is there an upgraded caliper that doesn't cost $3000 a set. I'm currently running Carbotech pads and stock rotors with Doug Rippie stainless pistons and wonder if just a little more braking wouldn't be nice. I like the idea of three or more pistons, but not at those prices. Any suggestions???
http://www.lgmotorsports.com/catalog...oducts_id=1514
You can use your stock rotors. It fits under the stock Z06 17" front wheel and the pads last for years, well maybe not years but a lot longer than most. I have it and love it.
Picture is worth a thousand words.!!!!!
[IMG][/IMG]
Tim
Former Vendor
Randy
Who told you this? some guy who sells another BBK set up??
Yes some states and provinces are considering ANY changes or modification away from OEM would be illegal.
1 Post
St. Jude Donor '08
Here is another possibility to consider.
http://forums.corvetteforum.com/show...highlight=SSBC.
Read post 48. SSBC brakes
Location: If you don't weigh in you don't wrestle Road America
I'm not sure stopping your car in a shorter distance is ever a bad thing.
While I am not a fan of VBP - mainly because they don't seem to be able to explain their spring rates (another story altogether), their C5 calipers with the Ti inserts are good stuff.
STOPTECH. Only system with balanced pistons, and very affordable.
However, if you stay stock, good cooling ducts (like sealed spindle ducts) and Ti inserts on the piston side only will help a good bit.
Cooling is always the limit. If you want to stop faster and more often, you HAVE to get rid of all of that heat.
I have a picture of my old bone stock 2000 with glowing red calipers using STOCK calipers. To me, that just means you need better cooling!
Please don't shoot the messenger.....it was a company here in Canada who specializes in brakes for all makes of cars. They do not carry many of the brands that are popular here on the forum, but Wilwoods were the only ones he signaled out as now being illegal.
Premium Supporting Vendor
St. Jude Vendor Donor '03-'04-'05-'06-'07-'08-'09-'10-'11
Give us a call and we can get you set up. Our calipers are wider than the normal Wilwood set up and we use the Stock Rotors with our G-Stop LG Motorsports/Wilwood set up.
BY using stock rotors, you can take advantage of the normally highest cost consumable being the rotors. You can continue to buy NAPA low cost rotors to keep your on track fun affordable.
Thanks and let us know if we can help you out.
Lou Gigliotti
PS, if you combine a set of our spindle ducts with your package you will have plenty of brakes.
Lou Gigliotti
__________________
LG Pro LT Headers, MOST HP, MOST TORQUE
http://lgmotorsports.com/gallery/alb...no_compare.jpg
LGM http://www.LGMotorsports.com
Winner Daytona 250
22 WC Wins
"Most powerful Corvette headers on the planet"
Winner Daytona 250
22 WC Wins
My Wilwoods front and rear work great with the NAPA's or the two piece Stoptech rotors from LGM which I use. LGM spindle ducts with the DRM ducts is great.!
Location: DFW This user does not support or recommend the product or service displayed in the ad to the right
Lou Gigliotti
Lou Gigliotti
Received 8,964 Likes
Bill
Glad to hear that it was maybe just an over zealous sales pitch....although he did intimate that this was a recent development. They say three times is a charm, hope your next inspection goes just as smooth as the first two!
We have our challanges here in the states as 96CollectorSport mentioned. Many times it is a matter of interpretation of the law.
We have some federal EPA law about Not removing ( HERE IS THE TRICKY PART) properly functioning OEM catylitic converters. Or some wording like that.
Well after I ran over those rake tynes which punctured my OEM cats, I had to replace them with High Flow cats.
