Koni 3013Sport
Old 06-07-2007, 07:10 PM
gkmccready
gkmccready's Avatar
Default Koni 3013Sport
Anybody tried the new inverted Koni 3013Sport shocks yet?
Old 06-07-2007, 07:47 PM
RAFTRACER
RAFTRACER's Avatar
I haven't personally sampled them yet, but I do know the developement car for them hauls................I know they are in stock @ Koni NA currently in reasonable quantities...
Old 06-07-2007, 08:07 PM
gkmccready
gkmccready's Avatar
Any knowledge of folks doing a D/A conversion? Cost effective versus a Koni 2812 or Penske 8300?
Old 06-07-2007, 08:41 PM
mountainbiker2
mountainbiker2's Avatar
My buddy just bought them today.
The fronts are the same length as stock when compressed. That's the good news.
The rears are 1/2" longer when compressed then stock ones. That's the bad news. Any car lowered more then stock height will have a bottoming problem.
They lost my business again.
Steve
Old 06-07-2007, 09:47 PM
gkmccready
gkmccready's Avatar
Can you run a smaller bump stop to get the travel back?
Old 06-08-2007, 12:00 AM
mountainbiker2
Not really. The bump stop is progressive. Cutting it would change the spring rate. Besides the bump stop is about 3/4". You would have to cut 1/2" off of it. That would not work. My buddy is going to check into having the shock made shorter.
Steve
Old 06-08-2007, 04:02 PM
TommyBoy72
TommyBoy72's Avatar
So now the option would be hybrid (new 3013 fronts with old 3013 rears)? I would think Koni will address the issue though. What have they told you about it (assuming you have contacted them)?
Old 06-08-2007, 05:27 PM
mountainbiker2
I bought these at Pro Parts in Canoga Park. They are a Koni dealer. We went over the measurements and we agreed that the backs were to long. They had no answer. What could they say "Koni screws up again". The old 3013's were to long too. I returned those also. All they had to do was match the stock shocks. Fronts are good. Backs are to long. These were measured on 04 Z06 shocks. The rear 06 Z06 shocks are even shorter then the 04's by a 1/4". That would make the 3013's 3/4" to long for us using the 06Z06 shocks.
Steve
Old 06-22-2007, 06:26 PM
loco engineer
loco engineer's Avatar
any update on this problem?
To Koni 3013Sport
Quick Reply: Koni 3013Sport
