Is anybody else using "J" compound Wilwood pads?
Old 11-17-2007, 11:53 AM
gkull
gkull's Avatar
Received 1,331 Likes on 1,059 Posts
Default Is anybody else using "J" compound Wilwood pads?
I just bought Wilwood calipers with 13 inch fronts. I've had heat problems in the past so i wanted a high friction pad. Just wondering what you others are using.
Old 11-17-2007, 12:01 PM
AU N EGL
AU N EGL's Avatar
J and E are street compounds IIRC. H's are the race compound
Old 11-17-2007, 04:42 PM
Gary2KC5
Gary2KC5's Avatar
Are you sure about the "J's"???
When I had my C5 and put a set of SL-R's on the front the J was the highest temp pad in endurance thickness.
I'm going to dig up and old receipt to double check...I know you know your stuff but I'm pretty sure J's were what I ran.
Old 11-17-2007, 04:53 PM
fcarga
fcarga's Avatar
H's replaced the J's. I think that the H's were supposed to be slightly more rotor friendly tho both J's and H's were/are hi temp/hi torque pads used on the heavier cars(3000#+). Gary(Hardbar) can tell us if he reads this thread.
Old 11-17-2007, 07:39 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
J's are great you just need spindle ducts from LGM and DRM or you will make BIG heat.
Old 11-17-2007, 10:54 PM
gkull
gkull's Avatar
http://brakepads.wilwood.com/02-graphs/j.html
I'm also having a race shop fab up three inch air ducting on all four. I've seen an inline fan setup also. They are supposed to wonders in the slow sections or if you stop.
Old 11-18-2007, 07:50 AM
John Shiels
the fans may block air at higher speed. What fans are you using, how much air do they push, and where is the break even point?
Old 11-18-2007, 10:35 AM
gkull
gkull's Avatar
No, I do not have inline brake ducting fans. The system i saw had twin feeds on the front. one with inline fans. So that would cover both high and low speed.
To Is anybody else using "J" compound Wilwood pads?
Quick Reply: Is anybody else using "J" compound Wilwood pads?
