Where to get tach signal...
Old 12-12-2007, 09:53 AM
Falcon
Falcon's Avatar
Default Where to get tach signal...
I just installed a Traqmate system in my car. It allows me to have various inputs from the cars mechanicals, so I need help with where to tap in for these inputs.
Where is the easiest place to tap into to get a tach signal? Brake pedal, and throttle position are a couple more. Steering angle?
Thanks!
Old 12-12-2007, 01:55 PM
Timz06
Timz06's Avatar
Hi Jody,
In lieu of previous experience, I would check the circuit diagrams and see where all of the signals go into the PCM. You should be able to find a spot to tap in if you follow the wiring.
Old 12-12-2007, 01:58 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
I have a ecu pinout sheet somewhere. I made one so I didn't have to remember all the pins. Now I just have to find it
Randy
Old 12-12-2007, 02:00 PM
wallyman424
wallyman424's Avatar
i can see it now, in a couple hours there will be a new thread:
"Hey guys, just drilled a small hole into my PCM, it dont work too well anymore"
Old 12-12-2007, 02:17 PM
Falcon
Falcon's Avatar
That's be sad if it wasn't so true!
Old 12-12-2007, 02:18 PM
Tourmgr1
Tourmgr1's Avatar
Here ya go:
http://forums.corvetteforum.com/show...ound+tach+wire
Old 12-12-2007, 02:24 PM
Bink
Bink's Avatar
Cruise-In V Veteran
St. Jude Donor '09
Jody - try this under the dash.http://forums.corvetteforum.com/showthread.php?t=619162
Old 12-12-2007, 02:33 PM
AU N EGL
AU N EGL's Avatar
Keep Jody away from any DRILLS . .
Old 12-12-2007, 02:39 PM
RAFTRACER
RAFTRACER's Avatar
Jody,
If you need something call......I will fax you what ever wiring diagrams that you need..
Old 12-12-2007, 02:42 PM
Falcon
Falcon's Avatar
Thanks guys.
BTW, I have these decals all around my car:
Old 12-12-2007, 02:43 PM
wallyman424
BAHAHAHA
nice.
Old 12-12-2007, 04:04 PM
Bink
Bink's Avatar
Cruise-In V Veteran
St. Jude Donor '09
Originally Posted by Falcon
Thanks guys.
Old 12-13-2007, 08:13 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Jody,
Did you get it figured out??? I can look in my books and figure it out again. I have been looking all over the place for my cheat sheet.
Randy
Old 12-13-2007, 09:27 PM
Falcon
Falcon's Avatar
Thanks Randy, but I think that link that was posted in this thread will get me what I need. I won't mess with it til this weekend.
Old 12-13-2007, 10:43 PM
racerwannabe
racerwannabe's Avatar
St. Jude Donor '06
i use the cable that goes to the distributor the one like a speedometer..oh wait that my '67
Old 12-15-2007, 11:17 PM
spazegun2213
spazegun2213's Avatar
Wally, i think you might need a few of these as well
Old 12-16-2007, 06:56 AM
varkwso
varkwso's Avatar
Originally Posted by Timz06
Hi Jody,
For some of us looking at circuit diagrams is like a dog watching TV..... I figure if he just drills into the top of the PCM he has a good chance of it working....
Falcon - will it have real time readouts in the car?
To Where to get tach signal...
Old 12-16-2007, 07:55 AM
Falcon
Falcon's Avatar
Yep, that's exactly what it's like when I have a wiring diagram in my hand, a dog watching the TV or a cat with library card.
On the in car display you can make about anything show up. But that's not what you necessarily want. It logs data for later analysis, It records segment times, G's, and pretty much anything else that would be pertinent. It can accept 5 other inputs (2 digital and 2 analog). those could be RPM, Oil Pressure, Throttle position, Brake position, Steering angle, etc.
The best feature is the predictive lap. It compares your current lap to the best lap you've had that point and displays that both numerically and graphically. That would be invaluable in qualifying or time trials.
Randy, if you get a chance sometime, I'd appreciate the ECU/PCM printout, that'd allow me to get some signals other than tach.
Old 12-16-2007, 08:03 AM
Falcon
Falcon's Avatar
Jeffro, here is the virtual dashboard of a partial lap. The data logger has recorded all the information and the video program synchs right up with the data. I had no inputs into the logger, what you see is only what it gets from GPS and accelerometers. If I had had the tack signal connected it would have displayed that along with anything else it captured.
The brake signal on the virtual dash uses any negative deceleration as braking. If I lift or feather the throttle any, the red light comes on.
Giddy Up!
Old 12-16-2007, 08:47 AM
AU N EGL
AU N EGL's Avatar
Great Video Jody.
Your "Compare video" is fantastic
Quick Reply: Where to get tach signal...
