Brake pedal Issue?
Brake pedal Issue?
First off I want to thank you guys for all your help with my pad selection. I ended up getting HPS rather than ZO6 pads b/c I needed them on a Saturday and Jegs did not have the ZO6 pads. In addition I replaced the rubber lines with 80k on them for Stoptech ss lines and the rotors with NAPA ultras. BTW they are painted but I DOUBT it will hold up.
Here is the problem......
I have to push the peddle to 30 ot 50 % before the brakes start to work. Also after the first push the pedal gets firm again but goes away. The car will do an ABS stop if you mash it but I expected there to be some brake action at 10% or so.
I have never driven another vette so this maybe normal but my wifes Jetta seems to engage the brakes immediately.
Some things to note:
During the install I replaced the lines one at a time with the master cylinder cap on. I did this in rather quick succession so I lost little fluid. Before the lines I replaced all the bleeders with Speed Bleeders also with the cap on. After I removed the old fluid from the master and replaced it with new. All the lines were bleed front then back one at a time never letting the master run dry. I don't know what I could have done wrong
BTW when I replaced the drivers rear I noticed that the bleeder had been seeping some fluid but the master was almost full. It my be worth mentioning but the fluid in the master was very dirty almost black.
Any Ideas or is this normal. BTW I bleed each caliper until the fluid came out clear.
Thanks Guys.
Thanks Guys.
St. Jude Donor '08
I have to push the peddle to 30 ot 50 % before the brakes start to work. Also after the first push the pedal gets firm again but goes away. The car will do an ABS stop if you mash it but I expected there to be some brake action at 10% or so. Thanks Guys.
You still have some air and crud in the system. I'd get a few quarts of Prestone Dot 4 , pull the wheels off one at at time and CAREFULLY bleed them again.
Make sure you got all the shims on the back of the pads seated correct. One slipped when I was changing pads and rotors last year and I got the same symptoms as you describe.
St. Jude Donor '08
U may want to check your brake line connections as well since you changed out the brake lines. Make sure air couldn't get into the system.
"All the lines were bleed front then back one at a time never letting the master run dry. I don't know what I could have done wrong"
I got a little lost here. The correct bleed sequence for your 2001 is RR,LF,LR,RF. How were yours bled?
I bleed out of sequence all the time and have no problems with brake pedal feel. I would re-bleed. When you bleed are you having someone hold the pedal down while you close the valvle? If the valvle is not closed, you suck in tons of air.
Usually when I have a low pedal, its a bleed issue.
Received 8,961 Likes
I have to push the peddle to 30 ot 50 % before the brakes start to work. Question 1 below.
Also after the first push the pedal gets firm again but goes away. Question 2 below.
This has been normal on all my Vettes for the last 20 years. It tends to help with heel toe braking downshifting.
2. Once the brakes start to engage does the pedal continue to slowly drop?
This may indicate that you have air in the line or you could have a slow leak in a brake line.
Bill
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,106 Likes
Sure fire method:
After positioning car, turn off key, pump pedal with car off several times to remove residual vacuum in diaphram, use pressure bleeder pumped up to no more than 10-12 psi, bleed brakes in recommended order. Pedal will be firm, no creep, and at full extension.
That is the correct sequence for the 97-00 cars. It changed in 01 when the brake line plumbing changed. 01 - 04 cars use RR,LF,LR,RF.
