Video: My big off at Roebling
Vetteless
St. Jude Donor '09
Was down at Roebling last weekend for the SCCA Jim Stark Memorial. Overall, the weekend was a frustrating one - primarily due to my own stupidity.
I managed to get down there with ZERO good tires, 3 sets of 8+ heat-cycle Kumhos. I tested on Friday and couldn't get below mid 1:17's, so I sprung for the only 315's available at the track which were a set of brand new Hoosier R6's. Very excited for qualifying Saturday AM, I went out and drove the sh** outta the car to get a best lap of only 1:19.1!!!
EDIT: Here is a link to video of my Saturday Qualifying effort. Constructive input appreciated!
I knew the R6's weren't as fast as the A6's or the 710's, but needless to say I was quite suprised I slowed down that much. And, in reviewing the video (I'll post it at some point), I don't see a lot of time I left out there, I ran 3 consecutive laps pushing everywhere I could all between 19.1 and 19.4. So, that pissed me off even more - now I was pissed AND slow AND broke!
The rain poured before the race on Saturday (becoming a theme with me it seems) but the track started to dry just before the race. So I hastily swapped back on my trusty-dusty 710's (gave up on the R6's) and headed out there. The track WAS dry, but there was standing water in several places - notably on the outside of the entrance to Turn 3.
I did a decent job dodging puddles for the first 8 laps, and then tried to turn in - in 4th gear - right on top of that little damp spot in Turn 3 on the 9th lap. Car stepped out, easy catch, but there was not enough race track for me to avoid the now sopping-wet and (much) slicker than greased-snot grass. I slid for approximately 15 miles - give or take - and hit the sand trap and touched the tire wall with both ends of the car - have thumb-sized scuffs to prove it. Amazingly, there was no damage other than 20 pounds of wet sand packed into every orifice on the right side of the car and 1 pair of CarbonX underwear.
D'oh! first link, was wrong race - HERE is the Saturday race with the off.
Here is Sunday's race - not a lot of excitement.
The video doesn't do justice to how slowly this all unfolded from the drivers seat, but I hope y'all enjoy!
We ran a little better (and safer) Sunday and got credit for both races, so the VetteRacer team marches on towards our Runoff's goal. We will be at VIR next weekend: car, enthusiasm, and most of my ego all still intact.
Man I can't believe you went straight off with that much speed in the wet grass and didn't smash that thing up. Makes me think I can push it just a little bit harder through there next time.
Leaves me wondering a bit why a newly paved track has standing water on it.
I just thought it would have been paved in such a manner as to avoid that.
any other thoughts on this?
Hey Mikah, Sunday's race was alot better for both of us than Sat.'s. You coul dsee how much time I lost for about the last three laps with my broken wheel hub. Had to not only replace the hub, but the caliper was toasted, the rotor also ate into the lower comtrol arm and had to replace it. I was lucky the wheel didn't come off.
Bob and I plan on seeing you at Nashville.
Vetteless
St. Jude Donor '09
Very glad to hear y'all will make it up here to Nashville, Melissa and I going to have to start preparing NOW to show the same kind of hospitality you and Holly show us every time! Thanks again, and glad you've got the black beast back together!
Vetteless
St. Jude Donor '09
Good point. Looking at it - nearly all the water was right on the racing line - in a "high lateral-G" area. I'm wondering if it's just that all the grippy cars going around there have already deformed the new surface just enough to leave some water.
Vetteless
St. Jude Donor '09
I think if I hadn't hit the sand broadside, I would've carried through the sand and into the wall.
I don't feel like I can take any credit at all for NOT hitting the wall - just plain dumb luck. Well, my wife is a good person too - maybe her good karma helped out some, certainly wasn't mine!
You contribute you save to luck, I think that you saved the car with some good driving.
Vetteless
St. Jude Donor '09
Here's video of my qualifying effort on Saturday.
Constructive feedback is more than welcome, I really felt like I was pushing pretty hard, but maybe I'm missing the obvious. It has happened before!
Mikah, my opinion is that you are turning in a bit early on several of the turns. Turning in later will also keep you of the rumble strips on 9, that is a bad place to be. I think turning in later you could pick up at least 1 second, maybe more. Tim
They also groove - every track I have been on puddles or get a runoff area over the track. At Mid America they had to pump the water off the track...
T1 & T2 look OK - stay in 4th....the tires seem to be giving you fits - 4th also helps this
Stay out on T3 till the end of the outside rumble - this line will make the exit of T2 smoother also. T4 line is the best race line - but the outside T4 line has a better exit speed in a C5.
Tap the brake in the middle of T5 (cannot tell if you do) to load the nose at "second " turn in to get more throttle in right afterwards. Go to outside to enter T6 (it flows great once you catch the groove) and stay mid track to hit the apex you have.
Too early turn on T8. Your line works the tires pretty hard and gives a real chance to make the Roebling ultimate mistake...
You are losing most of your time in T3 and that is also impacting your times through T4-T7.
merely my opinion - other people may run it differently...
mikahb what air pressure where you running?
To my understanding Hoosiers need one heat cycle to get the mold release off them and set the rubber compounds. Then need to sit for 24 hours before raced on.
