RGS610 Brake Fluid
Old 03-18-2009, 03:47 AM
Sidney004
Sidney004's Avatar
Default RGS610 Brake Fluid
This stuff is selling at $48 for a case of 12. Didn't this stuff used to be called GS610, has anyone used it before?
http://cgi.ebay.com/ebaymotors/ULTRA...Q5fAccessories
Old 03-18-2009, 10:00 AM
magnetic1
magnetic1's Avatar
Same bottle... cept GS610 was rated at 626 degrees dry and 417 degrees wet. The Ebay listing doesnt show a wet BP. If it is the same, it is good stuff, GS610 is no longer made.
Wilwood EXP600 fluid should be the same as they bought the rights to the fluid.
Quick Reply: RGS610 Brake Fluid
