External Oil Cooler on C6t Z51
St. Jude Donor '09
Perhaps someone has installed an external oil cooler (Earl's, Setrab, etc.) on a Z51-equipped C6, and by doing this has removed the oil cooling 'load' from the OEM radiator.
If so, my questions are:
(1) Is this a pretty straightforward installation?
(2) Can "adapters" be used on the OEM oil cooler lines to connect to the external cooler?
(3) What were your results?
Thanks!
Rob
Thanks!
Rob
