Question ls7 engine 07+ zo6
If you were to rebuilt this engine on a budget, what would be changed out first, to make engine bullet proof?
P.S. NO horsepower increase intended.
the problem with valve spring breakage is that the damage is often done before teh actual failure.. a simple overrev can over heat the springs and begin to weaken them.. then slowly they begin to fail until.. pop.. they break... sometimes in conditions you wouldn't expect (idling in a driveway at a traffic light etc..etc.._)
Good info here:
http://www.ls1tech.com/forums/6222846-post4.html
http://www.ls1tech.com/forums/6222849-post5.html
http://www.ls1tech.com/forums/6276875-post52.html
http://www.ls1tech.com/forums/6276892-post53.html
http://www.ls1tech.com/forums/6276916-post54.html
http://www.ls1tech.com/forums/6276931-post55.html
http://www.ls1tech.com/forums/6461626-post77.html
http://www.ls1tech.com/forums/6469716-post89.html
http://www.ls1tech.com/forums/6469799-post90.html
http://www.ls1tech.com/forums/6469801-post91.html
http://www.ls1tech.com/forums/6599854-post105.html
Here's the whole thread of Short Throw's build -> http://www.ls1tech.com/forums/genera...-race-car.html
CI-7-8-9-10 Veteran
Cruise-In IX AutoX Winner
St. Jude Donor '05-'06-'07-'08-'09-'10-'11,'19,'22
St. Jude/CI Name Tag Designer
hmmm
for me, the weakest point is not engine related, it's clutch related. Per the video done by Ranger on the clutches, my clutch fluid looks like crap after every event. The engine has been bullet proof. I boiled the brake fluid today. Time to find better fluid.
