What's your steering technique? Shuffle, fixed (9 & 3 etc.), or other?
Old 06-15-2009, 03:33 PM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
Default What's your steering technique? Shuffle, fixed (9 & 3 etc.), or other?
Just curious... seems that everyone you ask has a different recomendation and that it will vary car to car and track to track.
I've found that I keep my hands at 9/3 for the most part unless the corner calls for more then I pre-position my hands. For example, turn 4 at VIR I put my left hand at 12 and right at 6 then let the wheel come back to 9/3 as I unwind.
What do you find yourself doing?
Old 06-15-2009, 03:41 PM
mousecatcher
mousecatcher's Avatar
shuffle. like you, i tend to pre-position my hands.
Old 06-15-2009, 04:00 PM
Short-Throw
Support Corvetteforum!
Short-Throw's Avatar
Who are you asking? The Pros I've been coached by including and not limited to Pilgrim, O'Connell, Bagley, Kubinski, Brokowski say 9 & 3 is the correct placement for hands.
Years ago Driver's Ed instructed 10 & 2. As air bags made their way mainstream, many drivers punched themselves out because their hands were in the path of the inflating bags. (Of course in race cars with no airbags this is moot) 10 & 2 also does not allow the fullest range of the wheel to be turned without letting go.
Take a look at how the top Pro's hold the wheels whatever they are driving. This is how Bondurant teaches as well.
This is the only position that allows you to turn the wheel a full 180 degrees w/o removing your hands from the wheel.
Shuffling can put you in a situation where you are too late to have any chance to make a needed correction. Pre-positioning, as you call it, can also put you in a situation where you will only be able to correct the car one way and limited range coming back.
Proper hand position starts with proper seating position. Adjusting your seat to the correct height and distance from the wheel and pedals are critical to putting yourself in the best hand position.
Letting go of the wheel may be needed if you ever encounter a slide beyond what you expected (i.e. on wet pavement) Then as many have learned on a skidpad, hand over hand (followed by throttle) as fast as you can to catch it.
I will add that although you can still drive a car extremely fast w/o incorporating 9& 3, you are putting yourself at a possible disadvantage if the need for adjustment ever arose.
Racing is as dangerous as we let it be and as safe as we make it.
Mike
Old 06-15-2009, 04:02 PM
AlwaysInBoost
AlwaysInBoost's Avatar
on a road course I shuffle steer.
on an AX course I do whatever I can to make the car turn
Old 06-15-2009, 04:03 PM
wallyman424
wallyman424's Avatar
i steer with my knee most of the time.
Old 06-15-2009, 04:05 PM
Short-Throw
Left or right?
Old 06-15-2009, 04:14 PM
Falcon
Falcon's Avatar
Shlt! I'm so scared most of the time, I cover my eyes with my hands so I can't see what's getting ready to happen!
So far I've been pretty successful!
wallyman424
Originally Posted by Short-Throw
Left or right?
trade secret.
Old 06-15-2009, 04:16 PM
L98Terror
L98Terror's Avatar
W. Detroit Events Coordinator
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VII Autocross Champ
This is what I do, but what do I know
http://www.youtube.com/watch?v=QqeQ38XAUa0
Old 06-15-2009, 04:18 PM
wallyman424
you're not cursing or yelling at all in that video. no fun.
Cobra4B
Cobra4B's Avatar
Just curious... I find that it depends on the car and the seating position. I'm 6'4" and dont' always have the luxury of being in the 100% perfect seating position for range of motion.
Old 06-15-2009, 04:21 PM
Cobra4B
Cobra4B's Avatar
Nice... but some turns at VIR wouldn't allow that from my experience.
Old 06-15-2009, 04:27 PM
JVetthead
JVetthead's Avatar
I agree with short-throw... If your hands are anywhere other than 9 and 3 and you get loose you cant correct properly cause your hands are elsewhere and you will probably spin or at least lose momentum..
Old 06-15-2009, 04:48 PM
L98Terror
L98Terror's Avatar
Map of Grattan where Video was taken
VIR
Old 06-15-2009, 04:49 PM
L98Terror
L98Terror's Avatar
I had the A-Hole magnet unplugged
Old 06-15-2009, 04:59 PM
AU N EGL
AU N EGL's Avatar
Steering ??
Old 06-15-2009, 05:28 PM
stano
stano's Avatar
I use the 9 position, I drink my lattes and text on my cell phone with my right
To What's your steering technique? Shuffle, fixed (9 & 3 etc.), or other?
Old 06-15-2009, 11:42 PM
mousecatcher
[9 & 3] is the only position that allows you to turn the wheel a full 180 degrees w/o removing your hands from the wheel.
I guess I should clarify my own statement. I drive a formula car where the steering rack is very quick and you only get 180* of rotation total. No matter where I place my hands I can get a full turn on the wheel. I only move one hand when prepositioning, if I have to make a quick correction my other hand does it.
When I do a track day in the vette, I carry this technique over. Perhaps not the best in the vette, I personally couldn't say for sure myself but I guess I'll take the pro's word on it!
Old 06-16-2009, 12:04 AM
Short-Throw
Are you driving a PFM, Van Diemen, other?
I remember many moons ago, I was on a baseball team and commented how the pitcher was throwing sidearm and how it seemed wrong. My coach who overheard me said, "It's getting over the plate fairly quick, isn't it?" Over the years we have had a handful of major leaguers who throw sidearm despite the norm.
Perhaps of all the drivers today, there'll always be a few outside the third standard deviation, but I guess my main point was leaving yourself in a position at all times to save the car because you never know when that nanosecond surprise may appear.
Mike
Old 06-16-2009, 12:53 AM
sleeper02Z06
sleeper02Z06's Avatar
Wrong. You can run all of VIR Main in a Corvette from 9 and 3 without moving your hands, except to shift of course.
FWIW, after years of shuffle steering I became a bit faster and much more consistant keeping my hands on the wheel as much as possible in the same place. If nothing else it builds muscle memory. Much like shooting or any other sport that involves repetition, muscle memory and positioning is very important. If you have to shuffle steer, and you do sometimes, you definately want to "load up" as mentioned earlier. The way people shuffle varies, I try to keep hands on the wheel as much as possible by using what is widely known as the "sheriff shuffle", a method popularized by its use in the law enforcement community. Crown Victorias have a very low ratio steering unit so running most streets at 9 and 3 is impossible. Shuffling is a must.
Joe
Quick Reply: What's your steering technique? Shuffle, fixed (9 & 3 etc.), or other?
