best hoosier tire temp
Old 06-19-2009, 01:07 AM
jiggyracing
jiggyracing's Avatar
Default best hoosier tire temp
i am switching from Toyo and Nitto's to Hoosier R6's. What is optimal warm tire temp for Hoosier R6's on corvette c6?
Old 06-19-2009, 08:03 AM
L98Terror
L98Terror's Avatar
W. Detroit Events Coordinator
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VII Autocross Champ
http://www.hoosiertire.com/Tctips.htm
Tire Temperature Recommendations
For best performance the expected temperature range will vary from track to track. Generally, optimum traction will be generated when the pit lane temps show 180-200 degrees for the R6 in Roadrace applications, and 140-150 degrees for the A6 in an Autocross application.
Old 06-19-2009, 08:45 AM
AU N EGL
AU N EGL's Avatar
Much of this also depends on driving style
Many guys start out Mid 20s cold for pressure
26 f and 24 r and wind up low 30s HOT
Some times you will find the OUTSIDE front tire on the harderst corners needs an extra 1psi over the other front tire
tire temps needs needle pyrometer
Old 06-19-2009, 10:41 AM
jiggyracing
Default tire temps
thank you
Old 06-19-2009, 01:01 PM
HAVOC | Motorsport
HAVOC | Motorsport's Avatar
Default Hoosier tire temp.
How do you measure tire temp. ?
Call Jody LIFT @ 630-319-4180
for professional advice.
Old 06-19-2009, 02:55 PM
sperkins
sperkins's Avatar
And car set up. My severely camber challenged C5Z will roll over so bad on the front with 30psi cold that it will wear off the words on the side of the tire:
Not my actual tire pictured - just reference.
Old 06-19-2009, 04:26 PM
bowmanized
bowmanized's Avatar
I start a little closer to 30 so my first 2 to 3 laps are the fastest.
33 hot is really fun. Depends on the duration of the session.
If you want to finish 30 minutes strong start at 27ish.
PM me for ordering,
Mike
To best hoosier tire temp
Quick Reply: best hoosier tire temp
