Vision of a Race Car Driver
Old 08-19-2009, 05:57 PM
AU N EGL
AU N EGL's Avatar
Default Vision of a Race Car Driver
"Training for Speed
Tony Stewart, a two-time Nascar series champ, is considered one of the finest racers of his generation. Many things go into Stewart’s racing mastery, not the least of which is his vision. But it takes more than his great eyesight (20/13 in one eye and 20/15 in the other); it also takes his ability to quickly process what he sees around him. Traveling at 200 miles an hour, Stewart must make quick eye movements (called saccadic vision) and accurately assess what he sees and react accordingly. Here you can test your saccadic visual skills."
Test your vision HERE
posted in OT
Old 08-19-2009, 06:07 PM
drivinhard
Support Corvetteforum!
drivinhard's Avatar
100-80% up to .25 sec
after that I'm blind
Old 08-19-2009, 06:09 PM
CHJ In Virginia
CHJ In Virginia's Avatar
Well, I failed that test badly -- guess that the scotch I just finished might have some bearing on performance. Tried both one hand and 2 handed key entry was not able to note any difference in either method. Be truthful - how did you do ???
Old 08-19-2009, 06:21 PM
drivinhard
drivinhard's Avatar
I got 20% on .15s and .1 s on the 2nd time, after you kinda see what you are up against.
I can see where the .15s and .1s pop up well enough, but it's hard to "see" the pattern.
I liken it to "I can see the car spinning up ahead, but no I can't make out the sponsor decals on the door"
btw last vision check I had was better than 20/10 (I read the 10 line @ 26 ft). that was 7 yrs ago, my reaction time has probably slowed
Old 08-19-2009, 07:16 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Old 08-19-2009, 07:56 PM
Blue 92
Blue 92's Avatar
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
What patterns?
Old 08-19-2009, 08:20 PM
Bills Z06
Bills Z06's Avatar
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Geez, looks like I need to stay the hell out of my car!
Old 08-19-2009, 08:21 PM
L98Terror
L98Terror's Avatar
W. Detroit Events Coordinator
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VII Autocross Champ
LOl, I got 80-60-40-0-0
I remember some of the patterns but I type the keys wrong, maybe being dyslectic affects my results
Old 08-19-2009, 08:31 PM
Stevo92z28
Stevo92z28's Avatar
one of the times i did 80-20-60-10-00 lol!
Old 08-19-2009, 08:40 PM
ssdeuce
ssdeuce's Avatar
Old 08-19-2009, 08:49 PM
Aardwolf
Aardwolf's Avatar
100-80-100-0-0
80-80-60-0-20
The ones with the arrows going many different directions are hard to remember.
Old 08-19-2009, 08:53 PM
L98Terror
L98Terror's Avatar
If you type it in wrong like I do you can use backspace I thought it would help but then I got 100-0-20-20-0
Old 08-19-2009, 08:56 PM
Short-Throw
Short-Throw's Avatar
If this was real world cause/effect, I hit the Starter on pit out, banged the Armco, crossed the blend line, made contact with an oncoming car which flipped me upside down and I'm spinning like an inverted turtle.
I think I'm going to drive on my kids' X-Box from now on.
Old 08-19-2009, 09:12 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
I would still be shifting gears and braking like I was racing.
Randy
Old 08-19-2009, 09:26 PM
A-Pex
A-Pex's Avatar
Only reason I got 20% on the .1 was I happened to be looking right where it popped up. So the good news is if I happen to T-bone the spinning car in front of me I'll get to see his/her decal!
Old 08-19-2009, 09:39 PM
imp zog
imp zog's Avatar
I think I hit a submarine... wow that was bad. I too blame it on the scotch, although I haven't poured it yet.
Old 08-19-2009, 10:05 PM
dfinke23
dfinke23's Avatar
80
40
20
20
On the last two sections, if I happened to be looking where they appeared, I remembered them with no problem.
To Vision of a Race Car Driver
Old 08-19-2009, 11:19 PM
drivinhard
drivinhard's Avatar
I think that's the key, luck. same with racing right
Old 08-20-2009, 01:36 AM
waktasz
waktasz's Avatar
Your eyes have muscles and can be trained like any other muscle, both in speed in movement, and the ability to focus.
Now go hit the gym fellas.
Old 08-20-2009, 04:43 AM
worldsaway
worldsaway's Avatar
Can I drive with braille? I must need the ADD version. Ed
Quick Reply: Vision of a Race Car Driver
