Old 02-20-2015, 05:51 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior How-Tos
Print Wikipost
C5 Track Car \ HPDE Conversion: What I have learned!
Old 08-20-2016, 11:43 AM
  #421
rustyguns
rustyguns's Avatar
Originally Posted by FASTFATBOY
I think the very first thing you should do to a C5 before you even attempt to track it is remove and clean the radiator.
These cars are old enough now and have been driven enough that I bet 75% of them need the radiator pulled and cleaned as general maintenance.
Then you should keep it blown out as maintenance.
my first C5 Zo6 had heat problems when i first bought it used. looked in radiator area found it full of tumbleweeds FULL! amazing it ran as cool as it did !
So yeah everyone check radiator when they first get a Vette!!
Old 08-21-2016, 09:53 AM
  #422
carlspeed
carlspeed's Avatar
Any helpful hints with regards to power steering? I'm running a 305 square Pirelli take off set, and about mid way through each 35 second run I'm getting fading from the power steering. It'll come back after a few minutes of waiting for the next run, and then sure enough it's gone half way through the next run again. Suggestions?
Old 08-21-2016, 10:01 AM
  #423
FASTFATBOY
FASTFATBOY's Avatar
Put in Redline synthetic oil.
If it doesn't have a cooler, put a Z06 cooler on it. If it has a cooler, clean the outside fins.
Have the pump revalved for $100 from PSC.http://www.pscmotorsports.com/
Old 08-21-2016, 11:16 AM
  #424
carlspeed
carlspeed's Avatar
Thanks! I'm pretty sure the power steering fluid was synthetic already, but I'll drain and try something different. Just going to be a couple months before I take it out to another event, and if I had to do something like pull and send out the pump to have it re worked, this would be a fantastic time to do it. I drive the car pretty hard, and I know the pump was suffering. Just don't want to rely on the simple thing of fluid before next event unless it's supposed to pretty much definitely take care of the issue. I have a C5 Z, so that should have a cooler already right?
Old 08-21-2016, 12:07 PM
  #425
FASTFATBOY
FASTFATBOY's Avatar
Yes, I would clean the coolers fins.
Old 08-21-2016, 01:44 PM
  #426
rustyguns
rustyguns's Avatar
with all above. you have no idea how good Redline is, it is magic! make sure you flush the power steering system before you change it,
flush it every season!
and I am pretty sure you need a new power steering pump. might as well get the new one re valved too!
one more tip that really works wonders is to move the reservoir away from the engine. that really helps keep fluid cooler
Sam Handwich (08-21-2016)
Old 08-22-2016, 10:30 PM
  #427
Dirk Miller
Dirk Miller's Avatar
Default here is what I did
Driving hard on the track during hot ambient temps will drive a corvette owner nuts. At least it did for me until I put in a Setrab oil cooler. Easy to install and there was room in the engine bay of my C6. With temps over 100 F at Thunderhill it works for me.
Old 08-26-2016, 11:53 AM
  #428
dharmadan
Support Corvetteforum!
dharmadan's Avatar
No way I'd run that seat
FFB,
Can I ask why you say this? Am curious.
dan
Old 08-26-2016, 12:09 PM
  #429
danh52
danh52's Avatar
What's the reason for the revalve? What does it change? Feel or what?
Old 08-26-2016, 01:04 PM
  #430
FASTFATBOY
FASTFATBOY's Avatar
I never noticed a change in feel, I did notice a change in the heat in generated.
At really low speed it made the car slightly harder to turn, more noticeable when cold out.
Old 06-20-2018, 06:38 AM
  #431
TomdaToolman
TomdaToolman's Avatar
A big hearty thank you Zenak for all your time, energy and experiences that you shared with us! I have read this thread twice taking notes each time. Such a tremendous source of important info!
Thanks again!
Tom
The following 3 users liked this post by TomdaToolman:
72greg (04-26-2020), SacCityCorvette (07-20-2018), Zenak (10-11-2018)
Old 07-19-2018, 02:39 PM
  #432
Zenak
Terminal Vette Addict
Zenak's Avatar
Welcome
Thanks again!
Tom
Old 08-15-2018, 08:18 AM
  #433
NoradIV
NoradIV's Avatar
Hey man, little guy from the future here (8 years after original post, wow). This post has been incredibly useful for me. I have just started HPDE and have used this thread as a guide. I have started by doing as much reliability mods as I can affoard (RD radiator, DRM trans and diff coolers), and some comfort mods (track seat), then seat time (two sessions every monday and every track day in the weekends).
My next mods will be anything I can do to reduce ongoing costs (tire wear, brake cooling).
Regardless, thank you for writing this.
Zenak (10-11-2018)
Old 10-18-2018, 10:26 AM
  #434
jjc508520
jjc508520's Avatar
My track day friend has a C5 coupe - mine from the same year is an FRC. He mentioned to me that he boiled his PS fluid and had to pay to have a PS cooler installed - then proceeded to show me that the FRC comes with one - which at the time I did not know....
Old 10-18-2018, 10:30 AM
  #435
jjc508520
jjc508520's Avatar
I'm headed to a track day on Sat - mostly stock FRC (headers, flip-tie mod, ECS tune, Hawk pads/Centric slotted/cryo-treated rotors/braided brake lines) - I noticed last time that the brake fluid reservior was pretty hot after a run - I searched for cooling tips but couldn't find any - what about soaking a towel in ice water then just wrapping it around the reservoir?
Old 10-18-2018, 12:10 PM
  #436
rustyguns
rustyguns's Avatar
flush the power steering system and replace it with redline power steering fluid. Another cheap permanent fix is to move the reservoir away from the engine. Also you can add a bottle of Lucas oil, but if you drive in the snow etc it might freeze up lol I am in AZ don't have that problem
Old 10-18-2018, 01:20 PM
  #437
froggy47
froggy47's Avatar
What he said, redline, also if the rack has never been rebuilt, may be tine.
To C5 Track Car \ HPDE Conversion: What I have learned!
Old 02-17-2019, 12:09 PM
  #438
JumboShrimp
JumboShrimp's Avatar
Even though this thread is older than one of my kids - I just CAN'T stop reading it !!
I have nothing to contribute nor would I pretend to. But to those that did - Especially Zenak..... You get a Big Fat 'Atta-Boy' !!
I would think the OP either ended up with Carpal Tunnel Syndrome or Forearms like PopEye. Lot-O-Work got done here - THANK YOU!
The following 2 users liked this post by JumboShrimp:
JustMyMagination (12-08-2019), Zenak (12-26-2019)
Old 04-11-2019, 08:07 PM
  #439
ApexZ
ApexZ's Avatar
thanks for the inspiring thread.
Zenak (12-26-2019)
Old 12-08-2019, 07:00 AM
  #440
JustMyMagination
JustMyMagination's Avatar
Echoing a "Thank You!" to Zenak for the HPDE thread write-up. I feel like I'm 20 years late to the prom but I'm just now able to afford (in time and money) the C5 and the parts I've wanted since the car came out when I was in college. This thread is one of the most comprehensive and useful at generating ideas and important information for new C5 owners to begin with the end in mind. . . and save a lot of money from being wasted on silly useless mods. So here is a bump to the top and a cheers to the C5 owners that have contributed here, and to the future of the C5 that is still coming of age for guys like me just now getting into auto-x, drift, track and touring for the first time 23 years later!
From the Eye of the Dragon,
-A
Zenak (12-26-2019)
Quick Reply: C5 Track Car \ HPDE Conversion: What I have learned!
