Lesson for Track Newbies - How to Tell When Your Tires Are Corded
Old 09-12-2009, 12:38 PM
rikhek
rikhek's Avatar
Default Lesson for Track Newbies - How to Tell When Your Tires Are Corded
A lot of guys new to tracking ask how do you know when your tires are corded. They've never seen cords before......
I thought I'd be a nice guy and post a pic of what we're talking about when we say run them until they cord. They tires below are an example.
If you look closely you can see the "cords". There are actually two sets of cords. An outer nylon and the steel belted cords. The steel cords are generally thought of as the safety cords and are a good indicator that they are getting close to the end of their useful life.
There might be one more session in these but I bit the bullet erring on the side of safety and replaced.
Rick
Old 09-12-2009, 12:41 PM
AU N EGL
AU N EGL's Avatar
Oh Hell just let some air out too run on the edges
Old 09-12-2009, 12:42 PM
waktasz
waktasz's Avatar
What? You said you might be able to use them for one more session? Don't these track days have tech rules?
Old 09-12-2009, 12:43 PM
Last C5
Last C5's Avatar
What were these tires? (Brand & etc.)
Old 09-12-2009, 12:47 PM
rikhek
rikhek's Avatar
BFG R1. First set I've ever run. I really like them, I just ran too much pressure. I ran the same pressure as NT01s or RA1s which was too much. I still got 912 track miles out of them.
Rick
Old 09-12-2009, 01:26 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Even I wouldn't go out again on those.
Old 09-12-2009, 02:30 PM
johninar
johninar's Avatar
Hey Rick how much for the scrubs?
Old 09-12-2009, 02:34 PM
Sidney004
Sidney004's Avatar
What hot pressures were you running and what pressures will you run next time?
Old 09-12-2009, 04:00 PM
Han Solo
Han Solo's Avatar
Rick
I'm glad you don't live anywhere near me. I sure as hell don't want to be on the track with you if you think these tires are good for even a lap. These tires were probably unsafe about two sessions before you took this pic.
It might be okay to autocross to the cords but not for track driving. I've corded one tire autocrossing and it would push out three lanes wide at 40mph.
Old 09-12-2009, 04:30 PM
Bahnzii
Bahnzii's Avatar
Just out of curiosity could you have seen this coming by using an infrared temp gun??
Old 09-12-2009, 09:24 PM
rikhek
rikhek's Avatar
Some people really have no sense of humor or sarcasm..... I mean really, I wasn't even being subtle. Come on man, unclench those cheeks and have some fun!
Rick
Old 09-12-2009, 09:26 PM
rikhek
rikhek's Avatar
See, now that's what I'm talking about, a man with a sense of humor.
Good one John. ROTFLA.
Rick
Old 09-12-2009, 09:27 PM
rikhek
rikhek's Avatar
Same pressures as NT01 or RA1 which is 33 to 35 cold which goes up to 40 to 42 hot.
Rick
Old 09-12-2009, 09:35 PM
rikhek
rikhek's Avatar
Truly amazing how many guys don't see I was makin' a funny. COME ON, do you really think I was serious about them having any life!?!?!?!?!?!
How can you not read between the lines to see the intended humor.
Seriously, I looked at these tires very closely prior to the session they corded. I had a friend looking with me as I knew they were getting close. They were fine at the start. Session prior lap times were good.
And, there is nothing wrong with going to the cords, however, this is to the extreme and not recommended. Not sure what you're talking about but the majority of guys running track days go to the cords.
Rick
P.S. Autocross is for girls.......
Old 09-12-2009, 09:37 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
I wouldn't go to trailer with them.
Old 09-12-2009, 10:05 PM
argonaut
argonaut's Avatar
I got a set of rear pads you can run with those scrubs
Old 09-13-2009, 01:32 AM
waktasz
waktasz's Avatar
Rick
That was a dirty trick!
To Lesson for Track Newbies - How to Tell When Your Tires Are Corded
Old 09-13-2009, 11:57 AM
rikhek
rikhek's Avatar
There we go, now we're having fun!
Old 09-13-2009, 12:12 PM
WNeal
Support Corvetteforum!
WNeal's Avatar
Cruise-In Veteran VII
Cruise-In Veteran VIII
"Slower Azz Dog"
St. Jude Donor '06-'07-'08-'09
Some duct tape oughta get you another session.
Old 09-13-2009, 12:24 PM
RedLS1GTO
RedLS1GTO's Avatar
Man, you should have seen the pads that came off of the mighty C4 last time I was out there with you guys at Summit... you would have given me a LOT of room! I had a small, intermittent vibration the previous session that was more annoying than anything else. I pulled everything apart and it all looked pretty good and had plenty of life left to finish the day, but in the last (60% session) the right front let loose with a vengeance and as far as I can tell, simply broke the rest of the material off of the outside pad somehow. I think that might just be a result of asking a little too much of stock C4 brakes
Now, a few thousand dollars worth of Wilwood later, hopefully that won't happen again.
Quick Reply: Lesson for Track Newbies - How to Tell When Your Tires Are Corded
