Anybody have any experience with driving a corvette with drop spindles on the track? What adjustments to the suspension would you have to make since the center of gravity,the roll center, and the roll stiffness are going to change?
^^I believe LG runs on dropped spindles. Might try dropping Anthony or Lewis a PM on the subject.
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Darn right we did.
Depending on what you are going to do with the car, and how low the car needs to run they can make a drastic change in how the car handles.
Right off the bat they drop the car 1" over stock with no other changes. Of course control arms do not change angle.
Camber and Caster are increased, again with no other changes. Bump Steer has been corrected (you still need a bump steer adjustment kit depending on ride height).
Of course center of gravity is dropped as the entire car is dropped.
2600-3000/set. Currently, they are 1500/corner x 4 corners= a lot
Me like the newer price. The "a lot" price is a hard sell. But they do work very well. The last 4 or 5 racecars we have built have rocked the LG Uprights.
Randy
Thanks guys!
I'll get you pictures and your price on the new ones as soon as I have them in hand!
To answer the question: you need to run a shock length that is close to stock. The shorter coil over set ups that we have all been selling for years will be about an inch too short, which will have your suspension topping out over rises in the track.
You will not need to run as big of a sway bar as the "Arm" length between roll center and center of gravity will not be as long. This makes the car work better on broken or bumpy pavement. We found that we don't need to run as much static negative camber either, which helps in contact patch for braking and accelerating.
Our modular drop spindle allows you to shim upper ball joint height for fine tuning roll center and camber curve. Our modular steering knuckle is shimable too so you can effect ackerman, and speed up or slow down your steering as well. Our modular brake caliper mount system will allow lower unsprung weight for calipers using radial stud mounting. http://www.motorsportimage.com/pc-12...-spindels.aspx
