those with coil overs c5 and c6
did you make a hole in the rear tub to allow for remote adjustment without having to remove the whole assembly?
i am looking at pfadt install docs for their coil overs which i will be installing for a friend.
thanks
thanks
Yes. I drilled a 1" hole with a hole saw. I used a black grommet to plug the hole and it looked really nice.
The spot you need to drill is above the cavity the shock tops are in and it is sealed to the outside so nothing leaks.
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Does he already have his mind set on those?
You know with the LG GT2's we have a remote cable adjuster that does not require any cutting of the car at all.
No cutting and easy to adjust. In-stock and on special
Of course the G2's do not require either to be fast
everything is loaded in his car ready for me to install.
dont know if he knows about the cuts or not.
