Brey Krause lapbelt kits - how is your tunnel side done?
I put mine in, and have to take the seats out to re-do the tunnel side (the one that mounts on the seat belt bolt on the seat). I bought my bar and harness setup used (still fresh) but didn't find any good images of how to get it so I can get the sub belt and the lap belt clipped and unclipped. Do you guys ever unclip these things? The lap belts as it sits (and for both on the door side) are easy as pie, but how the heck do you position the other side to be easy to put on/remove when the slots are in an L arrangement?
Mostly, any photos of a six point snapped onto a brey krause lapmount setup?
Thanks!
Thanks!
It may come downto the seat you are using. I have used it with both the stock C5ZO6 seat and the Caravaggio race seat and did not have any issues. I had mine set up so it was postion like the OEM belt was.
looks like I've just got mine flipped over, this is on a stock seat. Mine the lower belt in your photo would have to be pointing towards the tunnel..
thank you sir, I appreciate the photo!!
Received 8,928 Likes
Bill
Thanks for the tip, I did grab a set of pins for next weekend. are your mount holes above or below the seatbelt connector?
As part of the kit you should have gotten a small collar that goes inside the big end of the BK bar and allows it to move around on the stock belt bolt.
Bill
Yea, I got mine used, and a few pieces were not present despite advertising, imagine my surprise for example when I was looking for upper seat belt bolts for the bar itself as those were also missing from the setup. I couldn't make those stock ones work for the life of me.. I just need to rotate the bracket 180 degrees and i'll be in good shape, thanks for all the help!
Terminal Vette Addict
I got the BK used as well. It was missing all the necessary bolts for the cross bar, and i was pissed. had an event and had to have the parts overnighted! Wasn't I more pissed when I found out it was 45 mins north of my OFFICE and I could have just driven up there!
hey of the 2 holes, which do you use for the lap? 6 point? i have had people tell me different then I use and their set up didnt make sense but made me question how i do it!
horizontal slot for the dual sub belt (so the belt lays flat on the seat under you legs) and the one that runs vertical for the lap belt so it's not twisting to go over you.
