C5 Brake Bleeding - Once Reservior is Dry
I just rebuilt my front caliphers the brake line hoses have been disconected and have drained the master cylinder reservior empty. I've put fresh fluid in and topped off the reservior. Is there any other procedure to be done prior to doing a normal brake bleeding job?
Received 3,844 Likes
"Ask Tadge" Producer
jas
There is still a good chance you'll get lucky and a normal bleed will work. I've seen horrible situations bleed easily, yet I've also seen very minor air intrusions cause nightmares. You just have to try it
