pfadt sways
pfadt sways
Hello all,
Looking at upgrading my c6z sways on my 06 C6 but got a couple of questions?
Does anyone know the weight of the stock sways with endlinks and also what are the weights of the pfadt sways with links?
Looking at the street sways but the pfadt site says they are 1.5-2 times stiffer than the z51 sways. Where does that leave them when compared to the Z sways?
Will the streets really be noticeable going from z sways to them for street/track/autox use?
I have the Pfatty race bars on my C5Z. love them and don't know the weight differance but they are very light for their tremendous size. If you want serious roll control these are the deal, and they don't change ride quality.
Can someone help me understand this chart? I really have no idea what the wheel rate on the left side means/refers to.
I'm assuming the "points" within each pfadt bar is representing the adjustability of the bar? So you can have a pfadt rear street bar as loose as a Z51 bar or almost half of what a phatty bar can do. Am I reading that part of the chart right?
Thanks.
Thanks.
I'm confused by the descriptor 'wheel rate' as well. Torque required for x amount of deflection makes 'engineering' sense to me, but wheel rate probably makes good 'racing' sense. Being that there are no units attached to the y axis, and the word 'relative' thrown in there, the chart has to be comparing the different bars by 'multiples' of each other or a standard (obvious standard would be something that weighs in at *1*)... but I don't see a standard, so I'm just going to guess that someone left the units of the graph. If that is indeed the case, it is poor engineering practice.
Always include units.
I would caution that it takes a great deal of patience to assemble and install these bars. Fronts in particular.
Thanks.
Thanks.
Terminal Vette Addict
short answer not much difference in perceived from c6z to streets unless you are a very experienced driver. Pfattys are another story, big difference.
