bad fire @ Texas IRL race
Old 06-07-2010, 07:21 PM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
Default bad fire @ Texas IRL race
haven't seen one this bad in a while
http://jalopnik.com/5557098/simona-d...-what-happened
Old 06-07-2010, 08:33 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
My first impression is the safety crew failed miserably. They should have been extinguishing the fire faster with her in the car. They should have been extracting her at the same time. Second would have knocked fire down Running around with a limp hose
They need to practice escape more also. Yes no?
Old 06-07-2010, 08:43 PM
BERETTA
Support Corvetteforum!
BERETTA's Avatar
Yes they do! It looked like only one of the track crew was trying to do something and then was having to ask the others to come help!
Old 06-07-2010, 08:53 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Very scary.
Old 06-07-2010, 09:44 PM
dvandentop
dvandentop's Avatar
wow very poor speed on the part of that safety team i deff would not want to be running any events there if they are on duty
Old 06-07-2010, 09:56 PM
SIK02SS
SIK02SS's Avatar
There was a problem with escape. I think when she hit the wall something happened to the tub and some obstruction prevented her from being able to get out. You could tell when she was there/stopped by herself she was trying to get something undone. Safety harnesses you dont need to be able to see to get undone, just feel, and in a formula car (any car for that matter) it's very easy to find. She also was struggling to pull herself out, and the fire crew struggled to pulling her out..just my opinion, but something was amiss inside the cockpit. Glad to know her only injury was 2nd degree burns to her right hand from trying to get out; could have been much worse.
and yes, the safety crew absolutely failed. It also took FAR too long for a crew to get there, and even longer for the 2nd crew to get there.
Old 06-07-2010, 10:51 PM
RX-Ben
RX-Ben's Avatar
Can the driver get out alone? The commentator said that 2 clips need to be undone on the head/neck restraint that is part of the car - and she was pulled out w/o that piece being removed. It didn't appear to be damaged, but it also didn't appear that the safety crew knew they had to remove this piece/how to extract the driver. Not to mention they took forever to get an extinguisher working.
Old 06-07-2010, 10:58 PM
mousecatcher
mousecatcher's Avatar
I doubt it. It was a light hit into the wall.
The cockpit surround wouldn't come out but I doubt it was because of the hit, more likely they just had a janky fastening system (not uncommon). It's very difficult to get out with the cockpit surround still in place ... as you saw.
Old 06-08-2010, 04:30 AM
WBHighwind
WBHighwind's Avatar
I've seen quite a few drivers get out without removing that surround but never in an emergency. There was likely a combination of fatigue, panic, and inexperience in that particular car that caused her to not egress as quickly as she needed to.
No doubt the safety crew left something to be desired.
There was also a pretty big fire at the rolex 6 hr at the glen race with the mike shank dp car. The driver egressed with no problems though aside from maybe missing the fire bottle switch. The real issue here was the fact that he had to drive with the car on fire for about 30 seconds to pit entrance to be close to somebody with fire fighting capability.
Old 06-08-2010, 06:27 AM
68sixspeed
68sixspeed's Avatar
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
years back I recall them testing the escape time for the drivers, making them practice, and of course there was no surround piece on the helmets trapping them in. The only reason I remember was a injured driver wanted to start the 500 with cracked ribs or something and he had to still meet the safety time to be allowed to start.
But regardless, the safety crew messed up, while the hoses were limp someone from each truck should have been out with fire ext. to keep the fire in check. Even the guy with the fire ext. struggled with the safety pin or something. Pins out when on the track guys!
NHRA's safety crew for the pro races is one of the models to watch, fire hose "guns" on the trucks, they are mobile before the cars stop but of course they only have a shorter strip of pavement and they don't have 30 other cars trying to get by either.
Old 06-08-2010, 06:39 AM
drivinhard
drivinhard's Avatar
the safety team for the IRL is pretty unique in that it travels with the team, and it's usually good, very good. trucks will be moving to a scene while the car is still sliding to a stop.
you don't usually see that happen in the IRL
Old 06-08-2010, 07:41 PM
05C6GAC
05C6GAC's Avatar
Not to steal your thread, but the Michael Shank DP car had a bad fire this past weekend at Watkins Glen. Looked like the driver got in a hurry and forgot to pull the fire extuinguisher handle after he tried to drive it back to the pits.
Old 06-08-2010, 08:24 PM
BrianCunningham
Hijack away, the more we know about how to deal with fire the better
Glad the driver is OK
get out 1st, worry about the car later.
Old 06-08-2010, 09:08 PM
Han Solo
Han Solo's Avatar
Looked like the last guy out of the second truck saved the day. I didn't see where he struggled to do anything but negotiate the limp fire hoses to get to the car. He sprayed a blast on his way to make sure it would work and did some fancy dancing to get in position to put the fire out. It also looked like he put the fire out all by himself and the hoses never played a role in the extinguishing.
Old 06-08-2010, 11:03 PM
joemoia
joemoia's Avatar
de Silvestro's view of it:
http://auto-racing.speedtv.com/artic...ol-under-fire/
Old 06-08-2010, 11:29 PM
efranzen
efranzen's Avatar
I've seen interviews with Stephen Olvey before where he said one of their safety goals in Champ Car was to have a safety team on the scene within 20 seconds of the car coming to a stop. Ever since I heard that I've timed it with a stopwatch while watching the races and I find it amazing how often they meet that mark. Plus, every safety crew has a member trained in emergency medicine.
I'd thought about that last year when Massa had his horrendous accident. The safety car with the doctor had to be dispatched from pit lane. And even though the accident happened near the end of the lap, the pace car drove an entire lap to get to the scene. It took almost 2 minutes before someone with medical expertise arrived. If it had taken that long when Zanardi had his crash, he probably wouldn't have survived.
Reading that article Joemoia posted, it sounds like it was a cascading number of errors that lead to it taking so long to get her out of the car. Much like how a plane crash is rarely caused by a single problem I suppose. Luckily the results weren't tragic this time, and I'm sure the safety crew will learn from what went wrong.
Stephen Olvey has a book called Rapid Response I've been meaning to read but haven't yet got around to it.
http://www.amazon.com/Rapid-Response...dp/1844253392/
Old 06-08-2010, 11:47 PM
Wayne O
CF Senior Member
Wayne O's Avatar
It's easy to second guess but it sure seemed like a cluster %#($ They got there quick enough but it took way too long to start knocking the fire back and begin extracting the driver.
To bad fire @ Texas IRL race
Old 06-16-2010, 11:23 PM
joemoia
joemoia's Avatar
Indycar investigation report on the incident:
http://auto-racing.speedtv.com/artic...ion-completed/
Old 06-17-2010, 08:55 AM
VetteDrmr
VetteDrmr's Avatar
Received 1,398 Likes on 749 Posts
Wow, what an insightful investigation! "We should have used the fire extinguishers". I won't try to get into the minds of the responders, but they sure didn't move very quickly at first, and no one from the first truck grabbed an extinguisher! I'm glad the only consequence is one of embarrassment for those crews; hate to even consider the scenario where de Silvestro is seriously injured.
I understand that fire is intimidating, but these guys are supposed to be PROs. Think they've got a way to go to get back up to the old CART safety crew standards.
Old 06-17-2010, 03:26 PM
BrianCunningham
no more fire hoses then?
Quick Reply: bad fire @ Texas IRL race
