4/5 point harness with stock C4 sport seats
posted in the C4 gen to no avail, was told to come here.
I picked up a set of 96 sport seats and later decided that I want to be able to use a harness for track days. Is it possible/safe to get a harness bar and have the belts go over top of the seat? If not, how hard would it be to get a set of bolsters for the belts to go through and put them in the back seats? (i am getting the seats recovered anyway) Any pictures of how others have done this would be appreciated.
It's not safe to just have the shoulder straps simply go around the seat back. If the straps fall down off your shoulders, you can be trapped in the car in the case of a crash.
While holes could be cut into the seat back, most sanctioning bodies also want the lap belts to go thru holes. And you still need a good anchor point for the sub belt (either a single belt or a pair like you would see for a 6-point harness).
If you intend on using a harness for autocross, track days or HPDE's, it will be better and safer if you have a true race seat. A seat like a Kirkey Intermediate seat and a set of Hardbar mounting rails, it doesn't take long to swap the seats for a race day. Corbeau, Sparco and others make good quality race seats.
If you plan on participating in several HPDEs and/or autocross events annually, then the racing seat and harness are the way to go. But if you are only going to do them occasionally, you may want to look into getting a set of Angel Pads from Angelwings Tech (www.angelwingstech.com). They work in conjunction with your current seat and belts and are a heck of a lot cheaper than the seat/harness option. I have a set and no longer come home with bruises on the outsides of my knees from trying to brace myself around corners.
Originally Posted by AU N EGL
5 or 6 point routed through seat holes.
No 4 points
No 4 points
I have the A4's in mine (see my thread) and they work well for that kind of use. I attached the lap belts under the stock belt so both can be used.
Number 1 issue is "submarining" where you slide out under the lap belt.
A 5 or 6 point isn't that much more and if you are going with after market seats you can get the anti-sub harness mounted using the rear seat mounts.
Yes, there are 4 point harnesses available - don't use them for HPDE.
Received 1,754 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I have been reading some on the 4 point, looks like I will go with a 5 or 6. Does the anti-sub belt have to go through the seat as well or could it just come up in front of it? I know that going through the seat would be "best" but if it is acceptable to go in front I may take that route.
Received 8,929 Likes
Check this link to see Schroth Belt info: http://www.hmsmotorsport.com/store/s...6.5-profi#2451 At the right hand side of the web page there is a link to a PDF document ( http://www.hmsmotorsport.com/docs/Co...structions.pdf ) that gives all the correct info for restraint mounting. You can find similar but not as detailed info from Simpson and G Force. I pointed you to the Schroth info because their restraints are currently being used by all of the big name NASCAR drivers and the owner of this web page is a known safety expert who advises NASCAR Teams and the BMW and Porsche clubs on safety issues.
No matter which brand of harness you buy make sure you buy a pull up harness. Trying to pull down on pull down lap belts where there is no room to pull is a real problem. The Corvette's center tunnel will prevent you from pulling the inside belt and you may not have along enough arm to pull the outside belt which has to be pulled from toward the ground from a point near the rocker panel.
Bill
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
I've been running a 6pt for years with the stock seats
run the submarine belts between the seat back & bottom.
If you can get a harness with a sternum strap get one.
Received 2,051 Likes
St. Jude Donor '13
Someone else posted that sternum straps had proven to be a hazard and were not allowed by many organizations. No personal knowledge here.
