Budget dedicated HPDE car: C4 or C5?
I'd like some opinions (and reasons!). For a "budget" dedicated HPDE car would you choose to start with a C4 or C5?
Edited to add that "budget" is definitely an important consideration. My impression is that the initial outlay for a C5 will be more. But will long-term costs be lower and/or "value" be greater?
If I were to do it all over again I would buy a roller chassis C4. There's one for sale for $1650 in the parts section now. You could find one for cheaper, say $1200. That would leave thousands in savings making it fast compared to buying a C5. I guess it depends on if you are planning to do the work on it or buy an already made track car.
You need to factor in your mechanical ability; there is a lot that could go wrong on a 15-20 year old car that you beat up on. You have to be able to wrench on a C4 yourself, otherwise the cost and frustration will be too much.
Define "budget".
I've run track events with my C4 for over 10 years now. I love my C4. If I were starting out today though I would opt for an early C5. It's just a better car and there are a lot more parts available.
Speed really isn't an issue and neither is cost since tires are going to be the same. The same with brake pads. When you look at what you spend money on it will be tires, gas, brakes and lodging. C4 or C5 those costs are going to be about the same.
Keep in mind that it will cost you just over a $1,000 a day to run track events. That's getting there, entry fees, hotels and food. You can throw in some routine upkeep into that number too. I know some of you run cheaper but is you like to sleep in a bed and eat decent food think $1,000 a day.
Richard Newton
Facebook
Richard Newton
As for which is better, it all depends on what your budget is... I have a track only C4 that is faster than most HPDE C5s out there.
With that said, if I had the cash I would start with a C5Z. It is a better platform for sure but if all you are looking for is HPDE fun you can build a fun, reliable, and fast C4 for a lot less than a C5.
I would venture to say that you could put together an HPDE ready C4 for well under $10k. No way you are doing that with a C5. Like I said to start, it all depends on how big your budget is.
C5 Z06 = $17,000-$20,000++
L98 C4 = $3,000-$8,000
LT1 C4 = $7,000-$12,000
Big difference
If you are set on tracking a corvette, I would probably go with a C5Z or a C5. However, there are tons of cheap track cars available fully caged and ready to race. I think you can have just as much fun in a lower hp race-prepped track car as you would in a C4 or C5 and it would probably be cheaper on parts. The faster you go down the straights and the heavier your car, the more you will spend on brakes, hubs, tires, and other wear and tear items. Lighter cars with less power are still a blast to drive and are cheaper on parts (spec miata, specE30, Legends, GTS cars, etc). Shoot, even my $500 Lemons mazda RX7 gets around the track pretty quick and is fun to drive .
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes
If I were starting all over again, I would get a good used '02 or '03 Z. I would do nothing but a track seat, harness bar, belts, and race pads. After a few events I might consider headers and honker intake with good tune. As soon as I started getting too much heat in the oil and tranny fluid, I would start thinking about buying a good used T1 C5 track car with cage. I believe most everyone that has been through the "process" would probably say this is not a bad way to go. Not the only way, but certainly one of the best because you can recoup good money in the Z and save a ton with a good used T1 when you are ready to step up.
I have just over 7k in my C4 . I just beat a bunch of c-5s at a HSAX at the Milwaukee Mile
They wrote a check , I turned a wrench
Wide open through nascar T3, T2 and T1 ...priceless
( had to lift a bit in T2)
My C4 still has the stock L98 with 147K on it. It makes 230rwhp and 320rwtq. It weighs 2780lbs with 3/4 of fuel and no driver. The car has a ZF6, clutch+aluminum flywheel, and C5 front brakes with race pads.
That being said my 99 FRC (when it was in bone stock form still) would have been the C4 any day on any track. Stick on a set of Non-DOT race rubber on a set of CCW classics and some race pads and it was sticking right with waaaaaayyyyy faster cars on A/R6's.
I would say for sure spend the extra money to get a C5. Sure you might be able to buy a cheap C4 and throw in a 383 or a set of coilovers, ect. But in the end the C5 is a better starting platform with way better technology and aftermarket support.
^^Our garage...And I'm still saying go with the C5!!
Redtopz is right. Buy someone else's money pit. Don't even think about building your own car. You can get a dedicated track car for less than $.50 on the dollar. Every week we have people on this forum going down that long slippery slope of trying to build their own track car. That's just crazy.
Buy someone's car. Let them put the big bucks into it. You're under $10,000 for a car that someone may have put $20,000 into.
Richard Newton
Vintage Motorsports Colummn
My Facebook
Richard Newton
My Facebook
No offence to the OP and welcome to the dark side, however . .
"budget" ?????
Buy a C5 and <koff> attempt to restrain yourself
Good Luck and Welcome to the addiction?
Now where is that poster about crack cocaine ?
"budget" ?????
